Car has rough idle and sputtering
So I bought a 85 corvette c4 and long story short it started sputtering at acceleration, also has a very rough idle. It sounds absolutely awful. So I replaced all the plugs, the cap, the rotor, and the mafs and it stopped... about 150 miles later the problem is back. What is happening?
So? The regulator could be problematic as could the injectors and even the pump could be causing issues. That or all of them could be fine and your spark is bad. Check spark and fuel first.
