Just installed Maximizer LT headers and the "Core Shifters" short throw shifter
Title. I was able to squeeze into a shop at the school that my dad works for so we were able to borrow a lift to do the work over Friday and Saturday (yesterday). Total time for both was about 12 hours but everything's in there! So in more detail, I replaced the stock manifolds and cats with catless stainless steel headers from the eBay brand "Maximizer" (who apparently also sell almost exact headers under the name OBX on eBay). For those of you who aren't aware, they come with circular port holes instead of the oval/D port holes like they should. I know that some people have used dremels to grind the port holes out but I didn't really care enough to do it on mine. We ran into a small problem as we couldn't get the air tube pieces to come out of the manifolds since the LT headers have the ports for them (for whatever reason). Ended up plugging the top inlet and using epoxy to temporarily plug the two ports on the headers while we ordered specialized plugs for them. Cut the stock exhaust to allow the included piping to fit into it and then used clamps to clamp everything shut. It's leaking slightly at the two clamps but I plan on changing the exhaust eventually anyway and it's barely noticeable in the meantime. Everything else bolted up right away, though. Just lots of cursing and frustration trying to work in the little room that's available. I ended up going with the Maximizer headers since they were on a random flash sale a few months ago; $250 plus $75 in shipping...couldn't pass it up. I'm glad I got them since the car seems much, much more responsive with them. She also has the deeper tone that I've been looking for, though it's quieter than I'd like it to be. The exhaust I plan on getting will obviously do-away with the giant mufflers and resonator so I'm sure it'll sound much more lively afterwards.
As for the shifter, jeez. The shifting feel makes it feel like an entirely different car. For those of you who don't know, the Core Shifters shifter is based on the discontinued Hurst shifter and I also got one of their shifter *****/***** since the factory one was a bit worn out. Shifting to every gear is much more precise and quicker. While I was originally worried about getting rid of the reverse lock-out function, I can say without a doubt that it's not a problem at all.
Weirdly enough, when we first started her up, the "Check ASR" light was on and kept coming on for the first 3-5 drives last night and obviously ASR/ABS wasn't working. As of this morning, the light is off and while I haven't been able to check if ABS is working, ASR is so I'm not sure what that was. No check engine lights, though!
Overall, it was a long job but the car is much more enjoyable to drive. Now I'll probably be sending the ECU in for a tune. Next significant project is probably to put nice Corbeau A4 or Evolution seats in her.
EDIT: Yes, I know I have a leaking valve cover gasket and it's messy...I have the gaskets, now I just need the time....
84 4+3 (06-16-2019)
Nice. On the port mismatch... a small amount of it isn't really a big deal especially stock. As you add more power it somewhat compounds but the center to center area is more important honestly. Iirc Some of the L98 manifolds blocked a decent chunk of exhaust port from the factory... the switch to D ports with the older style manifolds I believe. I may be remembering wrong though.
Enjoy.
Enjoy.
Enjoy.
Enjoy.
Sorry for bumping such an old thread of mine--
I just wanted to post a video I took this morning using a crappy GoPro knock off to give an idea of exhaust sound for anyone who may be interested in a similar "Ebay" setup. Just to reiterate: I have Maximizer long-tube headers and a chambered exhaust from HighFlo. I don't think the combined ~$1500 is too bad--especially since I did them separately. The car has been tuned ever since I put the headers on and I never put the car on a dyno before or after so I'm not sure about any performance improvements, if any, but she sounds mean!
Best pulls are at 2:30, 5:40, 9:30, and 12:15.
How much of a job/pain was it to install the short shifter? I have one but never installed it because I couldnt get the pin out. Not sure if its worth it or should just sell it.
Once you're underneath the car and can get to the top of the trans to knock the pin out of the lever, everything else is easy.
Core-Shifters is the one I used. $160.
I may elect to do that in the future but I think I'd need to look into electronic valves for it at that point. The current setup can already be ear-piercing loud near dividers and in tunnels if you have the top off. Surprisingly it doesn't drone at all so I definitely don't want to mess that up.
If you looking to buy a short shifter I have one for sale in the for sale section.
I saw that, I have read a lot of reviews on the B&M ripper and most guys seem to all agree the increased shift effort is not good, the ones that like it are drag racers. For street and road race use it is pretty much unanimous that the Hurst/core design that Chris Reinhart designed has the best feel, 40% less movement, 1.5" shorter, and less than 50% increase in shift effort, and the B&M is notchy, also takes over 2.5 times the force of a stock unit to shift it. Nice shifter, just not desirable for my application.
Bill Chase (08-29-2020)
My car originally has the black tag with lift ring for reverse, I am curious how much force it takes to get into reverse with the core shifter? Knowing my luck I would be rowing gears from 5th to 6th and slam it into reverse.. how does it feel going to reverse?
