help me with wheel decision please..
That was actually the previous owner (MSR on these forums), I believe at Motorsport Ranch just south of Houston, but I don't know what turn. So I guess the correct answer is "pretty fast." I didn't have a good recent pic at an angle that shows tire poke for the purposes of this thread, so I just posted that old pic.
Thanks guys.. no word back yet.. hopefully I didnt send him muttering something shaking his head..
Im misunderstanding backspace then. Im using the following to determine bs... he measured to the very outer edge with a straigh edge.. this drawing shows BS to be to the bead face.
https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
Hopefully he is out and will accommodate when he returns.. If I had just gone a little slower I woudnt have put everyone through all of this.
You'd have to look up offsets on a C5 to compare them. I know a C5 generally uses more offset than even a later C4.
But anyway, don't overthink this. The fronts will fit perfectly and the rears may or may not need a 1/2" spacer. It's that simple.
[QUOTE=MatthewMiller;1596803263]You'd have to look up offsets on a C5 to compare them. I know a C5 generally uses more offset than even a later C4.
But anyway, don't overthink this. The fronts will fit perfectly and the rears may or may not need a 1/2" spacer. It's that simple.[/QUOT
Trying to work out a deal with shipping.. I think I irritated him with all my requests especially after he agreed to ship.. will let you guys know..
And thank you all again for all of this information and especially your patience.
#34
You should have a good understanding of 'the math' - learn the math so you can accomplish a much better conversation the next time. Don't rely upon charts etc until you understand the math.
Where were the wheels? I ain't interested but maybe someone local to the guy would put an eye on them for you or maybe 'broker' the buy.
It's entirely possible that you ran upon someone that actually didn't understand. A seller will generally have much better success with a sale if he references 'offset' and lets a buyer determine fit.
Back-spacing only works where you've a tire/wheel combination to fit a specific wheel-well. Then it's all important!!
Master the formula for calculating back-spacing from offset and you can double check anything a seller mentions in a for sale ad.
Backspace = (Rim's Tire Width + 1)/2 + (Offset/25.4)
#35
My 2 cents worth:
Check the availability of big (285-295-315) 17" street tires. You'll find there's not much to choose from. I had to go to a 18x9.5 rear to find a decent selection of tires.
Later C4s (my '94) use the same offset as the C5s.
#36
I really like the continentals I just bought.. really quiet and a great ride.
I still have a foot in the door with the seller, if it doesnt pan out I may post the info for a local purchase.
#37
That is not true at all. A 17x9.5 later-C4 rear wheel has an offset of 56mm. I C5 rear 18x9.5 has 65mm offset. They can be used on a C4, but may need spacers to fit, and even if they fit without spacers they will sit noticeably inward of the OE C4 wheels and won't look quite right.
#38
https://www.zip-corvette.com/97-04-0...-5-18x9-5.html
These are what I bought for my '94
#39
This is incorrect then?
#40
Those are not OE wheels for any Corvette. They are reproduction C6 (not C5) "ZR1-styled" wheels in a size that didn't come on real ZR1s. The 2009 ZR1 had 19x10s and 20x12 wheels. While the wheels you bought will fit a C4 just fine, they have nothing to do with any real OE C5 wheels.
OE C5 wheels fit perfectly on a late C4.
