EDT automotive - engine clean
Old 03-19-2018, 12:57 PM
Yariv
Yariv's Avatar
Default EDT automotive - engine clean
Hi,
Do you know them?
Any experience?
http://www.edtautomotive.com/
Old 03-20-2018, 01:10 AM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Oh good lord.
BULL.
Old 03-20-2018, 12:31 PM
vette196
vette196's Avatar
Originally Posted by Tom400CFI
Oh good lord.
BULL.
3....2....1...
Where is Aklim
Yariv (03-20-2018)
Old 03-20-2018, 12:55 PM
Jaye Bass
Jaye Bass's Avatar
Old 03-21-2018, 11:46 AM
toddbvanslyke
toddbvanslyke's Avatar
Seems nonsensical to me. All the oil and "sludge" pumped out sounds good, but when fresh oil is put back in, it'll be dirty in minutes, too. Just looking at oil is relatively meaningless as its job is to clean the engine as well as lubricate and cool it. Regular oil changes with quality oil do a great job in keeping engines in shape.
Old 03-21-2018, 02:19 PM
Kevova
Kevova's Avatar
First GM has published information against flushing and specificity engine failures as a result would not be covered under warranty.
Under most cases there is no reason to have this done. If there's is intermixing of oil and coolant or other types of contamination. On a barnfind possibly, essentially just to get sludge and varnish out prior to trying to bring engine back in service. The chemical is pumped by the machine throughout the oil system. Oil enters engine at oil filter housing exit passage washing out 99% of the old oil and small particles are caught by filter. One problem is the process washes the oil off the bearings and can cause failure as a result.
Old 03-21-2018, 02:53 PM
84 4+3's Avatar
Received 1,373 Likes on 1,061 Posts
Well.... Kind of reminds me of the guys who have their diesel fuel polished in the boats....
Old 04-29-2018, 01:25 AM
Yariv
Yariv's Avatar
An update.
Made it last Friday.
I haven't noticed a difference but drove only for 30 mines.
No chips or other stuff were found in the filter.
Old 04-29-2018, 12:36 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Originally Posted by Yariv
An update.
You didn't notice how much lighter your wallet is? Thanks for the report/update, I guess. I can't believe you went though with this.
Old 04-29-2018, 12:58 PM
Yariv
Yariv's Avatar
I knew it won't be much difference from the beginning (maybe few HP).
The day before I made the cleaning, There was a Mazda 3 that it engine was saved. there were knocks and about 3 garages suggested to replace the engine.
Anyway the cleaning saved the engine. it took off lots of chips and rubber.
The engine runs smoothly.
Old 04-29-2018, 03:36 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
There was an engine that had bearing knock...and cleaning it "saved it"? Sure thing, man. Sure thing....
Old 04-29-2018, 08:27 PM
Need A Vette
Need A Vette's Avatar
If'n you're that worried, add 1/2 Qt of Transmission fluid to your oil then drive for 500 miles, then drain and change filter. will do the same thing. Thr trans fluid while an oil, is loaded with detergents, and it will keep the crap in suspension.
I wouldnt do more than 500 miles though...
D.
Old 04-29-2018, 08:33 PM
belairbrian
belairbrian's Avatar
Not hard to believe. Flush engine refill with 120w or so gear oil in place of the engine oil. Knock will disappear long enough to sell it.
Old 04-29-2018, 08:38 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Good point. Chain saw bar oil.
"But cleaning FIXED IT!"
Old 04-29-2018, 08:52 PM
Kevova
Kevova's Avatar
Flushing used with a repair may prevent future damage. Intake or head gaskets flushing the debris generated from repair. Barn find the hot fluid pumped through the lube circuits clearing the thickened oil. You may still want to prime oil system before starting. The materials caught in the filter/cup had to come from somewhere. If sludge and crud were the only reason a neglected engine had oil pressure at all. After cleaning the crud out it knocks with low oil pressure.
To EDT automotive - engine clean
Quick Reply: EDT automotive - engine clean
