1990 c4 tpi .no spark
Hello guys I'm new here I want to say thanks in advance I really hope you all can help me out with my car I'm so stressed out already. This what I have done so far.
1.i put new distributor, rotor and cap msd. Ignition control module Acdelco.
My car was working fine with the old distributor now that I was expecting to start it,it doesn't .that's all I did replace the distributor.... What the car does is this.. Cranks but not starts.. When my fusible link under the ecm is unplugged ,I have spark but I don't have fuel in the rails, and when it's plugged back. I have gas but no spark. I replaced the ecm and it was the same problem. Please guys any help I hope you all make time to help me out that's in advance.
Is the new distributor correct for the car? What's the part number?
Are all connections plugged in? There should be 3 plugs that connect to the distributor. Also check the connections, try wiggling the connections to the distributor while cranking and see if you get anything. One or more of the wires may not be getting a good connection, check them.
Zen Vet Master Level VII
I borrowed this from a previous post Loooong ago-- I had a hunch so I checked; "Double check oil pressure sending unit and sensor, ecm needs a 4psi signal to fire injectors and pull in FP relay. It may have been easy to knock off the wire loose when swapping distributor. The engine should start from the fuel in the intake, but "should" shut off if no signal. It isn't actual pressure, it's signal to ecm."
Also, check the TPS, if the unit reads WOT it will not start.
Pro Mechanic
If I were the OP, I'd be putting the original distributor back in. He says that it was working fine with the original on.
New distributor and new control module doesn't mix then went on to mention replacing ECM. Did OP mean maybe just MSD cap, rotor and ACD module?
Fusible link H (under ECM provides power to ECM and OPS)
There seems to be much going on in the original post.
