VR conditioner for Megasquit speed readout
VR conditioner for Megasquirt speed readout
Anyone using a VR conditioner board with their MS3? Wired in a JBPerf dual board connected to my VR wires, but not getting a speed readout.
Are you sure you have it wired properly?I had to reverse the polarity of the input when using MS3 on my Firebirds. What year are you working with and what trans?
While on this topic what other issues are you having with the system? I have ran MS1 and MS3 +3x on the L32 V6 and the LT1 both in firebirds with varying success.
Still thinking about getting a hand held O scope to verify if the JbPerf board is working, but no big rush. Reason I bought the board was to get a speed reading for TunerStudio and TCC lockup.
TCC is locking up based on MAP and throttle position, but I wanted to record speed as well.
I've not had any real problems with my MS3/3X..and the engine seems to love it too. The only issue I had was trying to set up a parallel install with the factory ecu and that large cap dist.
The large cap dist won't work with a Stealth Ram..
And for some reason, my radio isn't turning on. Not that I could really hear it over the music coming out of the unbaffled AHR exhaust
knikula (04-16-2018)
Yea VR sensors and resistance sensors don't share outputs well. Im glad you are having luck with the system, its always good to hear others are having success. What are you using for crank and cam ( if any) pickup. reluctors or is it all in the Distributor? I have every intent to reverse engineer the pcm on my 90 to try and replace the factory unit with my MS3+3x unit.I do think I will favor doing a full LS coil system over whats on there if I can.
I'm using a 36-1 wheel on the crank hub, with a Hall sensor. No cam sensor (yet). Did not go the dual sync distributor route due to not being that familiar with the setup, but if Holly's DSD works with a Megasquirt, that would seem to be ideal for a 8 coil setup.
Be careful with coil/distributor wiring. The Megasquirt is sensitive to electrical noise. Fried the factory ECU trying to route the MS wiring harnesses away from the distributor and coil wiring (MSD ign systems do produce a lot of juice). That's why I have that 36-1 wheel on the crank. No noise now, and real accurate timing.
