Driveshaft questions
I removed the driveshaft from my 85 to replace the u-joints and noticed that it has what looks like a little harmonic balancer on the front of it on the yoke that fits into the transmission. It appears that the outer ring of that balancer has slipped back about 1/4 inch or so and now I'm worried that it has caused the driveshaft to become out of balance. The car has a relatively minor high frequency vibration at highway speed which made me think that the u-joints were going bad which is why I removed the driveshaft to replace the u-joints. The front u-joint feels like it needs to be replaced so I'm glad that I removed the driveshaft to do the job but now I'm wondering if it will still vibrate because of that balancer ring that has slipped. I went on eBay to try to find another driveshaft with a good balancer on it and all I can find is only one driveshaft that will fit a c4 with a 4+3 stick shift trans and it doesn't have the balancer on it at all, it has a regular old yoke on it. I have a feeling that the yoke on that one was replaced with a standard yoke because it's balancer probably went bad too. There's tons of automatic transmission diveshafts for sale and a few 6 speed trans driveshafts for sale on ebay but only one for a car with a 4+3 and I think it is probably out of balance if indeed it's yoke was replaced with a standard yoke. Will a driveshaft from an automatic car or a 6 speed car work in a car with a 4+3 or are the lengths and/or spline count on the yokes different? Should I just put the new u-joints in the driveshaft that I have and hope for the best, hope its still in balance with the slipped ring on it's balancer? Is that balancer thing even needed? Is it really for balancing purposes or is it for something else? What should I do?
Many/most just remove the ring(dampener) and 'drive-on'. If you've no issues with the finish of the slip-yoke and leaks then I'd consider that. Generally no one balances the shaft after they remove it but if you've suspected issues now would be the time since you're doing 2 u-joints.
There should be drive-line shops in the area that can accommodate you.
Replacement slip-yokes less the dampener have been used for years.
NO THEY DON'T - spend the money, do the u-joints and balance. You don't even know where the 'ring' needs to be positioned. Any attempt to relocate will further destroy the bond.
Yeah I'm kinda leery on trying to push the ring back into position but I figured I'd mention it anyway. If it's a common practice to just remove the ring or replace the yoke with a standard yoke and call it a day I'd like to hear from some people that did that and get thier input on it.
Pro Mechanic
I agree. The DAMPER (it's not a "balancer", since it's neutral balanced) is an unnecessary device that some engineer must have calculated a need for...for some NVH criteria that none of us will ever notice or car about.
I can't for the life of me, even figure what the damper is supposed to be damping. Rotational velocity at either end of the shaft should be constant. Ditch the ring and move one.
I removed mine and the car still runs.
My outstanding local 'shaft' guy routinely checks the balance. The 6-speed length differs, having a ZF in place of the original 4+3.
Not sure why you'd want to start over after new U's on yours and don't recall the original '84 shaft having that wee 'balancer', but I'll try to find time to look for it later. Are there weights or drill-outs in that ring, indicating a balance was done and evidence it serves such a function?
Pro Mechanic
There shouldn't be any meaningful torsional vibrations -or change in rotational speed of the trans output shaft as it rotates, that would need damping.
You're right; a balanced drive shaft won't vibrate...it's balanced. The damper is not intended to "balance" vibrations. It's intended to dampen torsional vibrations; the accelerating and decelerating of a rotating shaft. You'll not the similarity in it's design, to the harmonic damper on the front of the engine/crank shaft. The function of that damper is to quell the harmonic twisting that the crankshaft experiences as it's "hit" by power pulses, across it's length -the crank twists like a torsion bar spring, and that twisting can start to "bounce" back and forth, like an uncontrolled spring. The harmonic damper on the front mitigates that (or tries to).
Pro Mechanic
I always thought that at speed in an overdrive situation and reduced RPM required there would always be related 'harmonic' issues. The axle ratio choices made for convenience and economy likely added to it's use. Not wanting to deal with customer complaints it very likely served a 'purpose' for new builds.
I believe that maybe the early Monza V8 that didn't have a dampener it was added as a weight to the transmission mount bracket. My sister had one of these and I recall issues for her.
Dampeners of some sort are added to almost all late model RWD cars I believe.
Pro Mechanic
IDK. My wife's CTS-V doesn't have one...but my Duramax does.
Engine pulses are dampened by the clutch damping springs or the converter clutches damping springs. The DS damper seems to me like it would only exist to dampen drive line torsion...which it's on the wrong side of the joint to do that, IMO. It would be nice to have an engineer who could explain what torsional inputs it's there to dampen, and why is it on some cars and not on others.
What year CTS-V? Doesn't it have a 'coupling' which actually amounts to a dampener I'd think?
Regardless the OP needs to remove and 'drive-on' - if he's sealing issues because of slip-yoke finish replace and drive-on. OP mentions issues that he thought drive-line related. Do u-joints and a balance 'once' and be done. A C4 drive-shaft most wouldn't like to do repetitively trying to resolve such a simple issue. $$$'s spent for the balance is a once and done no need to go behind yourself.
I pressed the ring off of the dampener (it was so loose I almost could have removed it by hand), installed the new u-joints, and took it out for a drive. Its much better than it was, it doesn't vibrate at highway speeds anymore.
Pro Mechanic
The CTS-V has had 'coupling vibration' issues mentioned for years. There's been various attempts at a 'fix' but years ago I believe a friend used this. I don't know if this specifically but very similar if it wasn't
This was from '12 and I'm sure you're likely a forum member so you should be able to see the snapshots.
http://www.cadillacforums.com/forums...c-install.html
You need to read the 'entire' thread. The friend never mentioned issues and I don't know whose 'kit' specifically but I'll ask if he recalls.
Tom400CFI (04-21-2018)
Pro Mechanic
Ha....my wife's V vibrates above 75 and it's the driveshaft. That thing is a heavy, dumb piece of ****. The center bearing started to go out; make noise...can't replace it....the DS assy is ~$1200. F-that, I said. I took my "hypodermic" grease needle and shot grease through the seal and shut it up over a year ago. It's still working. It's vibe'd since we got the car though (@28k miles). Irritating. I'll read the whole thread tonight. Thanks for the link.
