Meziere 30 or 43 GPM ?
Old 04-23-2018, 10:12 AM
johno504
johno504's Avatar
St. Jude Donor '19
Default Meziere 30 or 43 GPM ?
doing a PM on my existing pump prior to long trip out west in May. don't know what GPM is on LT4 now so planed to purcase the 43. Then I got to thinking(it happens) that the longer the coolant stays in the radiator the more heat should be exchanged, thus cooler temps. that plus the 30 GPM is $ 65.00 less money but looks to be identical in all other respects. which one would you go with ?
Old 04-23-2018, 10:29 AM
84 4+3's Avatar
Received 1,373 Likes on 1,061 Posts
30 is probably more than enough...
Old 04-23-2018, 12:21 PM
johno504
johno504's Avatar
St. Jude Donor '19
If , a BIG if , the 43 is pumping ( 8 ) 5 gallon cans of fluid in 60 seconds I don't see how any heat exchange could have a chance to happen at that rate of flow.
Old 04-23-2018, 12:25 PM
84 4+3's Avatar
The thermostat will still restrict the flow some too. Turbulence helps promote mixing for better heat transfer. It's a balance of turbulence and fluid flow. You'll hit a peak and it'll drop off. You need to find that peak for the system ideally... or figure out what the stock flow rate is and work from there.
Old 04-23-2018, 12:39 PM
BlowerWorks
Supporting Vendor
Support Corvetteforum!
BlowerWorks's Avatar
Oh Boy - you guys are really lost in all those wife tails !!! lol
Max flow always best - max heat transfer takes place with more flow to point of wanting turbulent flow. greg
Old 04-23-2018, 12:44 PM
Krusty84
Krusty84's Avatar
The myth of the "too fast of a flow rate" for heat exchange is one of my pet peeves. It simply doesn't exist. Other problems can arise from too much flow that can cause issues (like cavitation) but not having enough time for heat exchange in a closed loop system isn't one of them.
Old 04-23-2018, 03:52 PM
johno504
johno504's Avatar
St. Jude Donor '19
I called and spoke to Jerry @ Meziere , he told me the 30 will work for a street driven car , BUT more flow is always better. they will recondition my pump for $125.00. . since I don't know what pump is in the car, will just go ahead with plan A and purchase the 43. after all mo flo is mo betta. thanks all.
Old 04-23-2018, 04:17 PM
Pwnage1337
Pwnage1337's Avatar
Do they include a way to figure out belt routing? I want to run EWP on my L98 but can't find out how guys are doing it
Old 04-23-2018, 05:25 PM
Whaleman
Whaleman's Avatar
I am a Mechanical Engineer. It has been 50 years since I took "Heat Transfer" but I can attest you are correct. Dan
Old 04-23-2018, 05:31 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Big time. Another victim of LORE.
This is it, guys...listen to this guy. BlowerWorks (and Krusty and Whaleman) "gets it". More flow provides better cooling.
Old 04-23-2018, 05:33 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Not sure what brand, but I saw an ELWP at the drag track last weekend that had a pulley ON THE MOTOR, for the sole purpose of allowing one to maintain their stock belt routing. I though it was pretty trick.
Old 04-23-2018, 05:44 PM
johno504
johno504's Avatar
St. Jude Donor '19
CALL 1-800-208-1755 and ask them
Old 04-23-2018, 06:07 PM
Pwnage1337
Pwnage1337's Avatar
That would be the way to go IMO. Running from the ac compressor all the way to the Alt or however the hell you'd do it seems like a long stretch
Old 04-23-2018, 08:04 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Here is how I ran a meziere when I had a SuperRam.
To Meziere 30 or 43 GPM ?
Quick Reply: Meziere 30 or 43 GPM ?
