L-31 vortec eng
I added 1.6 rockers (had to open up the pushrod holes), LT4 springs (I've read that sometimes they fit and sometimes they don't) shim head gaskets and switched to a carb and distributor.
I had to drill/tap the forward clutch pivot hole to run it in a C3. I also redid the temperature sending hole to use match a '70s sending unit.
It's still weak when the rpm gets up the but those who've driven it think it a lot bigger than a 350 below 3000 rpm.
First, they last for freakin EVER, if you do a little maintenance
Second, the fuel economy is great; over 20 mpg in a 4x4, 1/2 ton truck
Third, the power was fantastic, for what it was/was in.
It's not more a "high torque engine" than any other EFI SBC; it makes about 340 tq...just like an LT1, L05 or L98 does.
L31 heads are fantastic for the money, and the L31 long block is a great, affordable way to get into a roller, 1 pc rear main seal, 4 bolt block.
If running typical TPI or other typical Gen I SBC intakes, some intake bolt hole modifications will need to be made and likely stacking intake gaskets too, since the L31 intake ports are higher/taller than typical Gen I heads.
While the "L31" injection system IS limiting, that is not why it fades above 4500 RPM; that characteristic lies almost exclusively in the cam shaft. The duration is tiny on the L31 engine; something like 191/196 @.050? With duration like that, no 350 sized engine is going to make power over 4500 regardless of heads, intake, injection or whatever. Swap the cam and you'll get more RPM.
if you want to see it...
