Fuel pump removal and install-tips? - Page 3 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 05-08-2018, 06:44 PM
  #41
vader86
CF Senior Member
vader86's Avatar
New RX brand pumps they do tell you to flip the polarity on some of them. Why they designed them this way I do not know.
vader86 is offline
Old 05-08-2018, 09:12 PM
  #42
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Originally Posted by aklim View Post
I don't think you hurt the pump but why is it smelling like gas? Regardless of whether I put the sock on or not, if there is a gas smell and you just pulled the pump, I wonder if you sealed it right? Was there a new gasket or did you reuse?
It was smelling like gas because all I had was a towel over the open fuel tank. So I before I left to work yesterday, I put the pump in the car and put the gas cap on. Just to eliminate most of the smell
Racetronix is sending me another harness, free of charge. Hopefully I get a good one. Also asked them how much for just underside tank connector.
1993C4LT1 is offline
Old 05-09-2018, 10:08 AM
  #43
aklim
CF Senior Member
aklim's Avatar
Kinda risky As I imagine my system only vents IF the tank pressure reaches a certain amount. You can have way more evaporated fuel at atmospheric pressure than at several psi. A spark and "BOOM". I hope they send you a new tank pump gasket. Like condoms, I don't reuse gaskets. Maybe if that are designed for multiple installs but even that is uncomfortable for me.
aklim is online now
Old 05-09-2018, 12:37 PM
  #44
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Yeah, they did send a new gasket.
Old 05-10-2018, 09:08 PM
  #45
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
So I told racetronix I needed a new in tank(bulkhead) connector. And they sent me this. It has 4 pins, instead of 3. Doubt it'll hurt anything, but just curious as to what you guys think.
Old 05-10-2018, 09:11 PM
  #46
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Old 05-10-2018, 10:29 PM
  #47
billschroeder5842
ZenVette Master level VII
Support Corvetteforum!
billschroeder5842's Avatar
I dunno.... Will it work? What does the extra wire do?
billschroeder5842 is offline
Old 05-10-2018, 10:42 PM
  #48
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
I'm not even sure myself. Will mess around with the car tomorrow, and see. The one they sent me has a very different shape compared to what is on the car.
Old 05-10-2018, 10:44 PM
  #49
aklim
CF Senior Member
aklim's Avatar
Will it even mate up?
aklim is online now
Old 05-10-2018, 10:58 PM
  #50
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Highly doubt it, but I hope
We'll find out tomorrow.
Old 05-11-2018, 02:25 PM
  #51
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
So no, it will not work with the car. There is a 4 pin connector on the outside of the tank, and it goes to the connector with the pins that are slightly burnt. There is no to disconnect it, unless you snip the wires. So my choices are: a new fuel pump tree for $300 at the dealer. Or(and I just noticed this) buy the outer harness in this pic from racetronix. The connection will work with the new in tank bulkhead connector they sent me. Would it be stupid to buy a new fuel pump tree? Mine is rusty as seen in pics.
Old 05-11-2018, 02:34 PM
  #52
confab
CF Senior Member
confab's Avatar
Did they send you the wrong connector?
Can they just take that one back and send you the right one?
confab is offline
Old 05-11-2018, 02:43 PM
  #53
billschroeder5842
I would never want to spend someone else's money (my wife does that for me) but you are rapidly approaching the RTFS moment.
Return to Factory Specifications
Old 05-11-2018, 02:47 PM
  #54
confab
CF Senior Member
confab's Avatar
And I would be mildly furious with racetronics over this.
It seems like you've spent a lot of money and all they have done for you is send you inferior parts, defective parts and incorrect parts..
confab is offline
Old 05-11-2018, 02:54 PM
  #55
aklim
CF Senior Member
aklim's Avatar
Furious would be a good start.
aklim is online now
Old 05-11-2018, 03:05 PM
  #56
confab
CF Senior Member
confab's Avatar
Yeah.... They're lucky he's so patient.
confab is offline
Old 05-11-2018, 03:12 PM
  #57
aklim
CF Senior Member
aklim's Avatar
I buy with Amex. You jerk me around and 1 call, that's all.
aklim is online now
Old 05-11-2018, 03:39 PM
  #58
confab
CF Senior Member
confab's Avatar
I try to be as gracious as I can.. But.. There's limits to that.
A lot of it depends on how they deal with this. At this point, I'd think they should be pretty accommodating.
confab is offline
Old 05-11-2018, 06:07 PM
  #59
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Thanks for all the feedback guys
This is a very simple job, that turned into a PITA
Well, they sent the correct bulkhead connector....for there bulkhead harness. So in pic 1, it is the harness that has the white sticker. Follow it, and you'll see it goes to top of the tank, which is the one with burnt pins. Hard to explain, hope I am making sense. And in pic 2, you can see their harness kit. When you buy the pump from them, it comes with everything minus that. Just posting all this stuff, in case someone goes through the same in the future.
The connection/harness I would need from this pic is, to the left the one with 4 pins. If I had that, it would work with the bulkhead connector racetronix sent me.
L
Old 05-11-2018, 09:50 PM
  #60
billschroeder5842
So.... is your car running now?
Quick Reply: Fuel pump removal and install-tips?
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
