Fuel pump removal and install-tips? - Page 4 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 05-11-2018, 02:12 PM
  #61
aklim
CF Senior Member
aklim's Avatar
Originally Posted by confab View Post
Yeah.... They're lucky he's so patient.
I buy with Amex. You jerk me around and 1 call, that's all.
aklim is offline
Old 05-11-2018, 02:39 PM
  #62
confab
CF Senior Member
confab's Avatar
I try to be as gracious as I can.. But.. There's limits to that.
A lot of it depends on how they deal with this. At this point, I'd think they should be pretty accommodating.
confab is offline
Old 05-11-2018, 05:07 PM
  #63
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Thanks for all the feedback guys
This is a very simple job, that turned into a PITA
Well, they sent the correct bulkhead connector....for there bulkhead harness. So in pic 1, it is the harness that has the white sticker. Follow it, and you'll see it goes to top of the tank, which is the one with burnt pins. Hard to explain, hope I am making sense. And in pic 2, you can see their harness kit. When you buy the pump from them, it comes with everything minus that. Just posting all this stuff, in case someone goes through the same in the future.
The connection/harness I would need from this pic is, to the left the one with 4 pins. If I had that, it would work with the bulkhead connector racetronix sent me.
L
1993C4LT1 is offline
Old 05-11-2018, 08:50 PM
  #64
billschroeder5842
ZenVette Master level VII
Support Corvetteforum!
billschroeder5842's Avatar
So.... is your car running now?
billschroeder5842 is offline
Old 05-11-2018, 09:41 PM
  #65
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Nope, but I'll get it sorted for sure, believe that. I can get it running by the time I go to bed. But as one of the previous posters mentioned, not worth installing it with the bulkhead pins showing signs of burning.
Old 05-15-2018, 10:13 PM
  #66
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
So I was seeing if I the top rubber fuel line I cut will still have enough to hook up to the metal line, there is not. As shown in this pic. Did some research on how to replace those rubber fuel lines. People were saying the rear bumper and gas tank have to come out. Fun
That is as far as I can get it in. Anything more, and you really pulling on it. The amount I cutoff is about 1.25 inches. That's just by going off the eye.
Old 05-15-2018, 11:40 PM
  #67
confab
CF Senior Member
confab's Avatar
I had the same problem with mine..
1) Use Gates rated fuel hose.. (Don't use "Continental" anything. I replaced that piece with their hose, even rated for immersion.. And it fell apart before I could test drive.)
2) If you reach back in there and work blind, you can change and clamp it.. Use a couple of good, rated, clamps, and a small combination wrench..
Another option would be a hose barb to extend that piece of hose.. To add on to it.
Good Luck!
confab is offline
The Following User Says Thank You to confab For This Useful Post:
1993C4LT1 (05-16-2018)
Old 05-16-2018, 08:41 AM
  #68
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
I like the hose barb idea! Did you replace the whole line, or just extended the line with the barb?
Old 05-16-2018, 10:23 AM
  #69
confab
CF Senior Member
confab's Avatar
I replaced the whole line, (It was from 1985, after all.. And I totaled it when I removed it.) but you can extend it with a barb and some good clamps if you want to.
The hardware store here has nice, brass ones. Something like that would work well.
PS: Be sure you use hose rated for this. Gates hose is good quality.
confab is offline
Old 06-18-2018, 06:53 PM
  #70
DAPOWER1
Junior Member
hey guys, How do I get to my F Pump I pulled my gas tank fill lid assembly and there seems to be another plate before getting to the bolts? my car is 89 convertible .Do I need to drop the tank...
DAPOWER1 is offline
Old 06-18-2018, 07:31 PM
  #71
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Not at all. Just loosen the bolts on the sending unit. It takes wiggling to get the pump out.
The Following User Says Thank You to 1993C4LT1 For This Useful Post:
DAPOWER1 (06-18-2018)
Old 06-18-2018, 08:15 PM
  #72
DAPOWER1
Junior Member
OK saw the rubber piece I'll get to the pump tomorrow
DAPOWER1 is offline
Quick Reply: Fuel pump removal and install-tips?
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
