1988 Vette Evaporator - Bad Accumulator Tank?
Hi I am not seeing the step for the vacuum pump pulling -30 for 1 hour. You should see all moisture burn off(so to speak in a mist). R12 may be different but I didn't think recharging the system was different. Here is my gauge readings after I recharged with 234. This seems to work good. Good Luck
You mean "134"?
Yeah, I know.....Gonna do a heater core bypass valve also. Even though the heater may be "off", I have done that to past vehicles and works well.
Sometimes one could get "residual/radiated" heat in the heater/evap box even though heater is off and this eliminates that completely...Just open it back up during winter and it works normally.
UPDATE;
Well, in between long periods of rain that are lasting 2+weeks, I dragged out my recovery tank and gauges and started siphoning off the excess refrigerant as mentioned previously.
I did this in short bursts and let system stabilize, playing with the pressures/evap temps until I could get them as low as I could w/out freezing the evap and, with this high humidity, that was no short task. The gauge readings came down nicely.
I don't know how much I took out and I will have to weigh the tank to determine this. Accumulator tank sweating "nicely" but, will still have to wait until I get this back on the road and test this in the typical temps of 92 - 96* here in Florida. I still have to repair bad brake line(s) going to abs near LR wheel.
