Under dash Module ID's for an '89...
Pro Mechanic
Looking for some ID's on these modules and relays under the dash in an '89. Each of these with either behind the stereo area or under the passenger's side of the dash. Thanks...
Is this a yaw sensor? On an '89?
These three...
This is a relay...what's it for?
Last, is this thing....
These three...
1st is lateral accelerator switch, 2nd snapshot start enable relay, alarm module and courtesy light delay timer, 3d amplifier relay likely and last is likely theft module
There's likely a number on the 'theft module' that would confirm. Colors on the relay if amplifier PNK, PNK/BLK, BLK & ORN. Part# if original maybe 14078902.
All of these look to have part# on them to confirm. Just post the actual number and they would be easily ID'd. Post them and I'll ID Them or use eBay and just search the numbers. That is usually a good confirmation but certainly not always. I use some older SPO catalogs I've got.
Pro Mechanic
OK. Thanks for the info!
I'll post numbers, shortly. This is for the 'Vette Kart project and I'm mainly trying to determine what pieces and harness I can ditch w/o affecting the way it runs. Numbers coming...
Pro Mechanic
Here are the numbers. FYI, there is another module in the same vicinity, but it has a big "PASS KEY" tag on it. I'm assuming that is for the resistor pellet in the key?
Anyway, here are the rest, numbers visible, this time.
14093107 - start enable relay
10097041 - alarm module (belts/light/key)
16039969 - theft module
10098435 - interior lamp timer
14093144 - lateral acceleration "yaw"
14029600 - horn relay
14078902 - amplifier relay for '89 (cooling fan for earlier years)
16135270 - Your 'PASS - KEY MODULE' since you know the 'resistance' would only be salable if someone actually wanted that resistance for matching their key or willing to change to your 'resistance' cutting a new key with their mechanical code. '89 Corvette only but some other GM's (F - body through '92 and some others)
Tom400CFI (05-07-2018)
Pro Mechanic
Thanks you very much.
I'm not looking to sell these....just want to simplify and reduce harness..."mass".
What is the "amplifier relay"? Stereo amp(s)?
It looks like I can only ditch the yaw sensor and interior lamp timer w/o affecting engine running...and maybe the amplifier relay?
Pro Mechanic
Cool...thanks! That's a goner too, then!
"Chop - chop - chop".
