Help! 1988, No brake fluid to rear brakes. Ideas?
I have a 1988 that has no fluid going to the rear brakes. Front brakes are fine. New Master already installed. Is this an ABS issue?
Any advise would be appreciated!
Did you get fluid to the rear brakes before swapping in the new master cylinder ? If the engagement rod is not adjusted correctly you won't get fluid to the rear.
A quick check, did you loosen the line to the rear just enough to see if fluid is weeping out when a helper steps on the brake pedal? If you
are NOT getting any fluid out to the rear at the master cylinder, you have to start your diagnosis there
https://shop.wilwood.com/blogs/news/...he-rear-brakes
https://www.google.com/search?q=no+f...client=gws-wiz
Job Completed
What I ended up doing was to bypass the ABS for the rear brakes. The rear brake side of the ABS was blocking any brake fluid getting through. The front was fine but the rear was zero flow.
I cut and removed the line that feeds the tee behind the left rear tire. Then I ran a new line back down to where the lines all make the turn over the frame rail and left extra line.
I cut the line from the master cylinder there and tied the two together with a coupling. No ABS to the rear but good brakes.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
You may want to do further refurbishing to the brakes later, especially for liability issues when you sell it to another unsuspecting buyer. As far as having ABS on one end of the car or the other, I would opt for ABS on the rear. If the rear locks up you have NO control over the direction of the car at all. Drifters use the parking brake to break the rear end loose every day.
