Need help to start and move 84 Vette
I had a problem, - the power window on the driver door stopped working. Took the door panel off and tinkered. I got the window to go up and down.
Now the drivers door latch cannot be opened with the inside or outside door handle or the solenoid. Reaching inside the door I could not find a lever that the rods were to unlock the latch.. Even trying to pry the plastic latch does not work so the door cannot be closed and latched. I may need to drill the rivets holding the inside door lever to get the tin 'pan out so I can get the latch assembly out and replace it..
But the big problem now is apparently the alarm system will not let me start the engine or even crank the starter..
The car is parked in the street where after 72 hours I can get a $72 ticket or have it impounded.
I pulled the connection to the horn but can still hear the alarm horn relay clicking. After 15-20 minutes the relay stops clicking but the key will not turn the starter even with a jump and the battery is charged..
How can I disable the alarm to move the car ??? We had to push it once.
Thanks for any help.
nlneilson (05-10-2018)
I thought just locking and unlocking the drivers door with the key would reset the alarm, that is what I did before having problems with the power window
What else needs to be done with the door locks to reset or turn the alarm OFF. ?
I think the key has to be held in the unlock position on the door. You could try the passengers side to disarm it. I forget if that works.
