Lighted rear view mirror for 84 Corvette?
Old 05-15-2018, 10:57 PM
auto_cran
auto_cran's Avatar
Default Lighted rear view mirror for 84 Corvette?
Can a rear-view mirror from a late 80's Corvette with the map light (as well as the light that shines down on the center console) easily be installed on an '84 - which has no lights at all?
Obviously my concern is the wiring...
Chris
Old 05-15-2018, 11:08 PM
aklim
aklim's Avatar
Received 2,240 Likes on 1,947 Posts
Chris
Sure. Tap switched power somewhere. I ran a wire years ago, forgot where but it was under the steering column on my truck so I can't see why you can't do that here. Any particular reason you are trying to do this? Would you be able to use a Gentex mirror with other features?
auto_cran (05-16-2018)
Old 05-16-2018, 12:55 AM
Hot Rod Roy
Hot Rod Roy's Avatar
I installed a JY dual-light mirror from an '89 Pontiac into my '84 years ago. I took power from the wire already in the windshield header that supplies power to the make-up mirror in the passenger side sunvisor for the two switched lights in the mirror, and ran an additional wire to the courtesy light circuit so the lights would come on with the courtesy lights. It's a nice addition!
Old 05-16-2018, 07:20 AM
auto_cran
auto_cran's Avatar
Thanks guys. The stock mirror will need replacing soon - and I like both lights that later models have - so figured I would try to go that route.
Using the power from one of the vanity mirrors was my thought exactly. Good idea for the courtesy light.
Just put it on my TODO list!
thanks again!
Chris
Old 05-16-2018, 08:04 AM
cdm747
Support Corvetteforum!
cdm747's Avatar
St. Jude Donor '17-'18-'19-'20-'21-'22
Good idea would be to put LED bulbs in them. Makes a huge difference in light output.
Old 05-16-2018, 09:12 AM
aklim
aklim's Avatar
http://automirror4u.blogspot.com/2012/11/limited-availability-gentex-genk42s.html?m=1
Old 05-16-2018, 10:08 AM
auto_cran
auto_cran's Avatar
The Gentex would be something I'd consider - but they appear to be no more (no longer available on Amazon). I'll keep looking though as I'm in no rush.
Yes - the LEDs are a must. One good thing the PO did was replace every interior light (even the vanity mirror lights) with LEDs (as well as the engine bay lights).
Old 05-16-2018, 10:34 AM
confab
confab's Avatar
I got one from Tom here on the forum for my 85. I think he was parting out a 1996? It was 90 something.
Since it was used, I asked him to include a little bit of pigtail with it and that made it much easier.
Fit great. Works great..
Old 05-16-2018, 03:52 PM
aklim
aklim's Avatar
I would look above where I showed the link if you must have a map light. I didn't so I got homelink since that was what made it unnecessary to have a remote in the car. Also, I didn't like the flipper which is so "yesterday" and self dimming is more "today".
To Lighted rear view mirror for 84 Corvette?
Quick Reply: Lighted rear view mirror for 84 Corvette?
