Replacement 84 power steering reservoir
So my power steering fluid reservoir has developed some leaks and is making a mess of the alternator and the engine around it. Has anyone found a replacement for the reservoir or am I going to be stuck trying to patch it and/or jerry-rigging a non-standard reservoir?
Thanks,
Reed
Thanks,
Reed
Pro Mechanic
You could buy a used one. I have one that is available if you want it:
Pro Mechanic
Sorry. I thought the '84 - '91 was the same reservoir.
Update to the 85 reservoir. Should be as simple as two hoses and the reservoir. Just check to see if the frame where the reservoir mounts has the holes already.
Pro Mechanic
The '85^ reservoir mounts to the "wonder bar". Doesn't matter if it has holes or not; GM used self tappers.
Thanks,
Reed
Thanks,
Reed
**This would be correct for '84
