Blowing fuses
Blowing fuses
On the way home to day I encountered a new failure on my 90 coupe. The radio went silent, the automatic climate control went blank I heard a pop and the antenna didnt retract with my radio. There was a smell of burnt silicon, like when you overpower a resistor, but nothing new developed on the drive home. Get home and find fuse #1 Courtesy ( 15A) is blown. Tried replacing the fuse and the antenna retracted right away. Turn the car on with the radio off and no pop. The climate control shows a temprature all seems well. Turn on the radio and the fuse pops. The radio still appears to be working but no sound and the antenna is stopped part of the way up.
To my understanding the "amp" portion of the bose sound system, the antenna, the cigarette lighter and the climate control are all on this fuse. Is there anything else on this fuse I am overlooking? If I'm going to have to tear the interior apart to find the short I would prefer to do it once. On the same note is this something a bad speaker amp would do?
Zen Vet Master Level VII
Something is grounding out.
I know that a multi meter and a diagram are the smart choices, but I'll recommend a old school (it is faster) method. Since you have isolated it to the radio system, disconnect cables and pop a new fuse in. Plug in the radio, then edm, then speakers(s) then antenna until somting blows the fuse. Also when pluging wiries in, flip the dash lights on/off to make sure that this system is not problematic.
Once isolated, you will need to see if the wire or the "mechanism" (whatever?) is casuing the ground. If the unit (again whatever the object) is not broken, My guess is loose wire rubbed through and are making contact with something and grounding out.
Now having said that.... check your antenna ground strap first. That is on the divers side rear and gets dirty fast loosing contact.
Space387 (05-19-2018)
Will do. My gut is saying its one of the 4 speaker amps as I have heard some popping in the past. If the antenna cycles without an issue it shouldn't be the ground strap right?
I never heard of amps blowing fuses but you never know.
Enjoy your electrical hunt
Well I found my issue.
In the words of Adam Savage " Well THERE'S yer problem." Tested the car with just this amp out and although its now severely lacking it works without blowing fuses. Already have a new set of four from a good setter purchased
