95 Corvette ZR1 wont start
95 Corrette with 102,000 miles. Does not start. Fuel pump was not turning on. Replaced fuel pump, fuel filter and fuse still no start. Banged the fuse box on the passenger side, I heard the fuel pump on ! I’ve been told maybe the contacts on the fuse box are dirty (?)
would that be the next thing to do?
thanks for any suggestions
Enjoy while you can.
Received 2,685 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Lot of great members and helpful info in that section of the forum.
The comment about checking the contacts seems on track but better to get insight from those with that engine model.
Best wishes for a simple fix!
Received 19,291 Likes
'20-'21-'22-'23-'24
Moved to C4 Tech.
95 Corvette ZR1 won’t start
thanks Route99.
I guess it would help to know ithe engine is a 350 cubic inches & manual transmission 6 speed.
I hope the first suggestion is not clean the contacts, not sure if I’m qualified to take that fuse box out.
Thanks for your input. Mike
