Adjusted TPS to 0.54, now idles at 1300
Yeah, all times I checked it, max was 2.6. Even looking this morning, blades wide open only got 2.6. Wouldn't surprise me if it was bad, or even if that was the right TPS on there. I cannot understate enough the years of bad mechanic work and poor maintenance i've had to undo on this car
And I agree, OP should check the reference voltage. If the reference voltage was at 2.3, then 2.3 is all he will get from the TPS. In addition, his '0' mark would be off if the reference was half of what it should be.
The MAF cars still did take a 0% value to account for small variation in the reference voltage - I had started my car back when it was MAF with my foot barely on the gas, and it ran terribly. Key off, key on, and back to normal. Plus, the shop manual gives a range of voltages that is 'acceptable' for a 0% value, and shifts where the WOT is based on that initial value.
2.8 was all I could get out of it. And that was depressing the TPS lever, not just tb lever. Picking up a new TPS tomorrow and we'll see how it turns out. Tune should be here tomorrow as well.
If you have 5V reference and 2.8V by depression of the TPS lever, we are done with the the TPS. Ebay special Slightly used
So, picked up a new BWD TPS and installed it last night. Odd thing here is, still only getting 2.2V at WOT. Getting 5V at at bottom battery input. I cleaned the connector terminals, no corrosion was present. At this point, I'm stumped
When I had accidentally hooked my MAP sensor up backwards, the TPS input would not pick up until about half throttle, and wouldn't get above 2 volts. I used the same ground for TPS and MAP. So power went into the ground on MAP, then from the power on map, to the same ground wire as TPS.
Nothing got broke, but sensor input for both sensors was garbage. I don't know the way your car is wired, but I imagine you have several sensors sharing the same ground coming back in to the ECM - my car did. I wonder if there is a short/bad conection somewhere in the harness, or if a sensor that is also on that ground is acting up.
Try this, if you can - get a wiring diagram for your ECM, and ideally, a 5 volt power supply of some kind. I suppose you could jumper from another sensor, but a run from an external supply would be ideal.
First, start off by disconnecting the other sensors that share a ground with the TPS, one by one, and then all at the same time. All different combos of disconnected sensors that are on that same ground. Check TPS signal voltage each time.
If a certain sensor appears to be at fault, it may be bad. If that test ends up being inconclusive, then we know the power/ground wiring to the TPS is not shorted by another sensor.
Next, I'd try hooking a 5 volt supply up to the TPS, attaching the signal wire, and measuring signal voltage again, just to check.
I'd then repeat this at the ECM, only you will need to take the pins for TPS voltage and ground out, and hook them to the supply. What's the signal voltage do then?
Im definitely getting 5v at reference, so strange. I’ll have to look up the ground path in my FSM and check it. On the bright side, I installed the tune in the car and wow, completely different car. Actually has some go now haha. Cant imagine how it'll feel when this gets sorted out
Did a quick check of the TPS connector. Top wire ground will complete the 5v circuit coming from the bottom supply. The culprit seems to be the ECM reference wire. Once again, it only reads .40 at rest and WOT 2.2V. So, thinking maybe a connector issue? Loose at the point of the connector. Visually, the wire is intact until it enters the harness firewall passthrough. And the part I can see entering the ECM visually passes the test. I'd hate to think it's a bad ECM, but between the connector, the ECM reference wire, and the ECM, these seem to be the culprits.
#33
#34
#35
You could measure resistance of the wire itself by taking a multimeter and going from the TPS to the ECM connector. Make sure you don't test resistance there with the ECM plugged in, that could hurt it.
#37
Oah yeah, duh lol. Its been a long week man. I’ll pull the pin number from the FSM and test it
#38
While you've got the ECM pin pulled, you could reconnect the ECM minus that pin, and then measure the voltage with the wire off of the ECM - that way you can find out if the issue is the ECM or not
#39
The facts as the lay now:
TPS is receiving 5v.
TPS top ground wire holds 5v and has no resistance to ground.
ECM reference wire itself has 0.00 ohm resistance.
When power supplied, TPS connected, probed and checked, ECM reference wire at rest is 0.30v now and WOT is 2.12.
At this point, the finger is pointing to the ECM... Frustrating if this is the only thing wrong with the ECM, but really, it's kinda a big thing lol.
#40
Damn, I wish I had checked this before I did that. I ohm'd the ECM reference wire from connector to c13 as per FSM and got 0.00. I used the tables in the web link one of the members here posted for the Ohms of the TPS, confirmed all the specs within 0.5-1. Hooked power back up and probed power input and top ground and got 5v.
