How do I remove Pin from headlight
An easy job turned into endless banging. I have no idea how to take this pin out. I've used drill bits, hammers, self tapping screws, wd40, nails. I just cant get it out. Chrisfix love taps the thing like 4 times and his comes out.
Any help would be appreciated thank you
Use a pin punch. You can get a set at Harbor Freight cheap:
https://www.harborfreight.com/8-piec...set-93424.html
Or Lowes:
https://www.lowes.com/pd/Stanley-FAT...Set/1000085213
Any other hardware store should have something similar. Just pick one that's approximately the same size as the pin.
Or Lowes:
Or Lowes:
Or Lowes:
Sorry, I don't know off-hand what size it is. I see Harbor Freight has two stores in Bakersfield, if your location is correct I'd just pop into one of those and grab the cheapo $9 set.
