Length of vacuum hose to cruise control
96 CE/LT4...Does anyone know the length of hose needed to replace the 7/32" hose that goes to the cruise control and through the firewall? You know...the one that's always rotted out. Thanks!
Iirc it isn't too long. Maybe 4 feet? You can always cut to length.
racerseks (05-24-2018)
It just shoots from the vacuum canister to the brake pedal right? Or did gm move the module from by the battery in later years?
It goes from the cruise control servo, through the firewall. There are two hoses going to the servo, and it's the 7/32" one...bottom, I believe..Pretty sure it goes through the firewall to the brake pedal.
