1988 KC4 oil cooler adaptor plate
Question, what is the difference between a stock by-pass oil adapter and the adapter for the KC4 oil cooler setup? My parts book does not list by-pass as part of the description of the KC4 adapter. Each has a different part number. I think it is the same part but the KC4 has the by-pass feature removed. Asked Melling about it, they responded that it looks like their by-pass adapter, but that's all. Any knowledge or comments about this out there? Trying to put this rescue mission back to rights. Thanks
Have you looked at them? The standard bypass filter adapter is just really is so a spin on filter attaches to block. It doesn't need a gasket.
Oil cooler bolts on use same holes. It does require gasket and coolant hoses.
I don't know how well the c\k adapter would work on corvettes. I haven't one on a Vette. It would allow for larger remote mounted oil cooler.
Try using a modern remote cooler like a DeRale coolers with the oil filter adapter.
I have a Buick with the "Optional Oil Cooler" on it from GM and it is close to worthless. The design was terrible, they circulated coolant around the oil going to and from the filter. The whole device was maybe 4 inches tall and it pushed my oil filter way down.
Good luck but check out the newer technologies!
I have acquired all the needed parts except for GM #10055722, the cooler adapter, which is different from GM #3952301 by-pass adapter which is on the block. I need to know the difference between the two parts, in order to acquire or make a replacement. The cooler itself was made by Modine and is GM #14049217, contacted Modine but have not heard back. Anyone ideas?
Where did you get the 14049217 you use as a reference? That ain't a cooler. There were I believe 2 of that type I'm aware of 14084369 for Corvette and 14092135 for Camaro/Firebird.
Do you now have a cooler, 2 studs, 'correct' gasket, the sleeve and snap-ring? This is an L98 cooler and appropriate hardware. This particular is for the Camaro/Firebird. I believe that the only difference for the adapter was 'height'(maybe) that when attached with the correct studs, (the studs positioned it) and also the adapter height kept you from over tightening the sleeve that held the cooler and ruining the gasket to cooler/block seal. If you could confirm the dimensions then the 'by-pass' restriction is different because of the cooler.
I'd think that unless a 'restoration' of sorts you just use the filter and stock adapter. TOSS THE COOLER or I believe sometimes referred to as 'HEATER'. I don't know or care if original hoses are available or NOT. I don't know if I have the correct adapter or not but I have cooler, sleeve and snap-ring for the Corvette. Might have the adapter.
Maybe someone has an L98 with KC4 disassembled and could confirm the casting information on the adapter and the dimensions.
+++Years ago I've seen mention actually removing the by-pass mechanism with a plug. Here's a more recent post with an explanation.
https://www.corvetteforum.com/forums...post1575617275
So you've an '88 that has the KC4 RPO and you want to put it back stock. Is this correct? I ask only because of some information you've mentioned.
Attachment 48290937
Attachment 48290937
That is the same part they used on my Buick.
https://www.rockauto.com/info/304/12...mary__ra_p.jpg
This is from Rockauto and they get $217.79 for the original GM cooler.
I would again find a good aftermarket cooler over using the GM overpriced part.
Good Luck with the Cooler!
viking7 (06-06-2018)
