4+3 tranny install
4+3 tranny install
I cant seem to be able to get the c beam back into place
the tranny is already back in,does the transmission have to go in with the c beam or can it be done with the tranny already in? Any help in detail would be greatly appreciated.
COYER77 (06-02-2018)
before transmission is in you should have the c beam on the rear end, in all the 4+3 and ZF transmissions I have always left the most rear bolt in the c beam in but loose.
I have found that if the c beam is removed from rear totally the rear flexes up making it a bear to get together
COYER77 (06-03-2018)
