emergency and turn signal flasher
Old 06-11-2018, 04:29 PM
Greg Johnson
Greg Johnson's Avatar
Default emergency and turn signal flasher
Hi Friends,
I have to replace the flasher on my 94. This has been a tough job to complete. It is difficult to even get in there and then you have to find the flasher. I have the service manual, but cannot identify the flasher. Can anybody give some advice or help? Thanks.
Old 06-11-2018, 04:39 PM
84 4+3's Avatar
Received 1,373 Likes on 1,061 Posts
On my 84 it is a round metal relay can looking thing. Behind the radio iirc. I'm not sure on the 94 if it is similar. I pulled my dash and center parts (radio and panels above it) and saw mine just sitting there...
Greg Johnson (06-12-2018)
Old 06-11-2018, 07:08 PM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
If you have the actual Helm FSM HAZARD 8A-201-20 FIG #33 and the DIRECTIONAL 8A-201-24 #41 & 8A-201-25 #42
BOOK 2 8A-201 is after the wiring diagrams. You should have no issues.
Old 06-12-2018, 12:25 AM
Greg Johnson
Thank you!
Old 06-12-2018, 12:45 AM
ChumpVette
ChumpVette's Avatar
Received 1,290 Likes on 872 Posts
Originally Posted by Greg Johnson
Thank you!
And in a 94, it is not in that location.
It is underneath the driver side hush panel. You need to remove the panel and also the metal crash brace to access it.
Greg Johnson (06-14-2018)
Old 06-12-2018, 12:53 PM
Greg Johnson
I was about to look and see if I could remove the metal. There is no way to even see the flasher. Thank you.
Old 06-12-2018, 09:11 PM
Greg Johnson
Originally Posted by ihatebarkingdogs
The metal comes off pretty easy if you know that the upper corner of the center console side panel carpet folds down to access the inboard two bolts. The little "flap" is held up with Velcro or a dab of cement. Makes the flasher job easy-peasy if you know about the flap to get to the two bolts.
Did all that and can see everything under the dash, but cannot identify the flasher. I have the GM Service Manual and it is not too clear. Is their a number on it to identify it? No tube-like can flasher like the one I got to replace it. Hope I find it soon because I have a lot of parts to reassemble! Thanks to all for the help.
Old 06-12-2018, 09:32 PM
ChumpVette
ChumpVette's Avatar
Flasher is the silver disk looking item on the left.
Old 06-13-2018, 08:32 AM
WVZR-1
WVZR-1's Avatar
Good job!!
Sometimes 'IN LIVING COLOR' just works. Your snapshot pretty much confirms the FSM 8A-201 is correct.
Old 06-14-2018, 01:29 PM
Greg Johnson
The photo you provided was exactly what I needed!! The flasher was broken and I could not identify it as the cover was gone and there was a little coil of fine copper wire hanging there. I had not seen the inside of a flasher before. Thank you kindly for the excellent help. Got it all back together and it works.
To emergency and turn signal flasher
Quick Reply: emergency and turn signal flasher
