Which type of led conversion should I go with?
Hello, and thanks for taking the time to read this.
I have a 96 base coupe, and my goal is to eventually replace every light bulb in the machine with an led. However, for most important lights, the headlights and the brake lights, I have a decision to make.
I can either use something like the following, which replaces the entire surface with an led cob.
https://www.corvettecentral.com/c4-8...2fled-lamps%2f
Or I could simply replace the bulb itself with a compatible led (for the headlights I would get one of those kits that convert from sealed beam bulbs to h4 bulbs if I use this method.)
https://www.superbrightleds.com/more...ofit/2625/5698
Are there any practical differences? Because I would honestly prefer to go with the second method, as I think it looks better.
