Nash 4+3 Overdrive Problems - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 07-10-2018, 12:18 AM
davidmcnutt
Junior Member
Default Nash 4+3 Overdrive Problems
The overdrive on my 1985 C4 (manual transmission) has been giving me problems. It started misbehaving after I took a longer trip than just to and from work. The overdrive button would come on, but instead of shifting at around 50 mph, it starting shifting in the high 50's and low 60's. Now, when I press the overdrive switch, the overdrive will engage once around 63ish mph and stay engaged for about a minute, but then slip back out of overdrive. It will still kick into a lower gear if I put the throttle down, but it won't reengage into overdrive. The overdrive light comes on when I turn the switch on. I have already replaced the overdrive relay, and refreshed the fluid and filter on the overdrive unit, but that still hasn't fixed it. Any help here? Thank you!
davidmcnutt is offline
Old 07-11-2018, 12:38 PM
CF Senior Member
Not an expert by any means but it would sound like you may have a couple of issues. First the early ones have a kick down cable. Iirc if that goes out of adjustment it can cause weird issues. Second if you get it then drop out you're losing holding power. So there could be a pressure or clutch issue. How was the fluid whe you refreshed and what type did you use?
84 4+3 is offline
Old 07-13-2018, 12:58 PM
davidmcnutt
Junior Member
The fluid was super black and dirty, and I refreshed it with non-synthetic transmission fluid
Old 07-13-2018, 12:59 PM
davidmcnutt
Junior Member
Originally Posted by ihatebarkingdogs View Post
If the OD light is ON, it should be in Overdrive. If it is dropping, or slipping back into Direct, with the light remaining ON, or the light comes on but it does not upshift into Overdrive, There is a problem. Slipping OD clutch, or hanging thrust washer.
If the light is ON, it should be in Overdrive. Period.
The cable on a 84-85 is a Throttle Valve cable and is used to modulate the up-shift. It is not a "kick down" cable. Kick down is controlled by the ECM based on VSS and mostly TPS.
Thanks for the insights! I'll check the light again.
Old 07-14-2018, 02:04 AM
CF Senior Member
I always think kick down for whatever reason. I don't know enough only because mine has been trouble free.
I do agree, burnt fluid means it is probably due for some work.
84 4+3 is offline
The Following User Says Thank You to 84 4+3 For This Useful Post:
davidmcnutt (07-16-2018)
Old 07-16-2018, 12:27 PM
davidmcnutt
Junior Member
Thanks for the help, much appreciated!
Quick Reply: Nash 4+3 Overdrive Problems
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
