Grease Sleeves in Poly Pushings?
Fellow Vetters,
After a poly bushing has been installed, should the inside of the steel sleeve and the bolt that passes through it be greased too? If so, I assume that white grease would be the best to use, especially if the car is driven year round. Thanks in advance!
SnorT91Man
SnorT91Man
Fellow Vetters,
SnorT91Man
SnorT91Man
I'd probably do it that way, and for the same reason. That's the only reason to put anything inside the sleeve. The sleeve and bolt should not be rotating against each other - the bolt cinches the frame tabs to the inner sleeve so that the sleeve remains stationary while the urethane bushing rotates around the outer surface of the sleeve.
I greased all the parts on my POLY installation on my C3. Six months later they started squeaking and they only stop when I spray liquid graphite around the bushings. I hope that the Polyurethane products have improved, I did mine over 22 years ago and they are still tight, they just squeak when they get a chance. I have found that the graphite does the best at quieting the bushing down so every spring I spray the bushings well.
Now that I am getting older I don't hear it as much, maybe there are benefits to getting old with a Corvette!
Red 91 (07-19-2018)
Not Vette specific, but my rule is when doing suspension work I put silicone grease on everything that slides, rotates, pivots or compresses. The only exception is things fitted with a zirk fitting, they get chassis grease of course. From my point of view it can't hurt and one thing that totally sucks is taking apart a new suspension to stop a squeak (ask me how I know)
Finalist 2020 C4 of the Year - Unmodified
Actual poly used makes a difference. For example Energy Suspension Red polys tend to squeak eventually. Black, on the other hand, are graphite impregnated, lube built in. I use the grease on the black anyway, makes them install easier if nothing else.
I greased the poly bushes liberally in and out with the lube that came with them, was good for a year and got the odd squeak now and then.
I ended up going to Banski heim jointed struts and trailing arms, no more squeaks from the rear .
Have been toying the idea of grease nipples to the front upper and lower control arms to grease the polys from time to time....
Water spray will eventually get in there, the grease gets absorbed a little I think.
A lot on this forum say they need to be removed and greased every 10 or so years, but my case is every 2 to 5 .....
