C5 to C4 Brake upgrade
Hi - I have a C4 with Salad Shooter Wheels, 17" x 9.5" 56MM offset. Is there anyway to Fit the C5 Brakes under these? I put all together and looks like im .25 to .5 inches too wide. Has anyone ever used spacers to get them to fit and would it work? I should have studied a bit before i invested in 2 sets of these wheels for my track car so would like to get them to work with these as opposed to buying new wheels all around. The second Pic is so you can see the Wheels.
every mod to a c4 results in a problem, and every fix creates another one !
when I did some reading about the swap others either used adaptors (as opposed to spacers) or machined out the inside of the stock rim.
not sure that cutting out the inside of the stock rim is good for strength or balance but some have done it.
Minimum thickness on a 'pass through' spacer that retains a 'hub-centric' mount that with your use I'd think requires it is something very near 15mm. I believe mine are 16mm and the fellow who did mine thought he wanted to go no less than what we did. I don't recall - it's been 12/13 years. Also many sanctioning organizations don't allow spacers. Adding a 15mm pass-through allows you to retain the 'hub-cenrtic' feature but requires longer wheel studs also. Studs are no issue.
I didn't think that quality 'adapters' were available in less than maybe 19mm. How about a link to what you've bought. These have a 'hub-centric' to wheel and also the hub feature on the car? You want to 'try before' buying more.
*** If the adapter is drilled through each stud OD to ID it would seem much easier to drive the roll-pin through rather than attempt to remove roll-pin when attempting to replace a stud with a slide-hammer or whatever.
sgtcongo (08-01-2018)
SGTCONGO,
Im also just about to upgrade my 85 to big brakes. (after reading about a million forum posts on the topic :-). I face the same question.... what I will I do about spacers/adapters, to make my sawblades work?
With all the write ups out there, the one thing that I havent been able to find documented is the caliper overhang measurements of a stock C5/C6 caliper/rotor setup.
(the measurement from the rotor's hat face wheel attachment point to the farthest outside edge of the Caliper). Most after market manufacturers provide that info for their own product models.
Since you are in process of doing the C5 mod, and have the calipers and rotors installed, would you mind measuring that distance and posting it. ?
Im likely going C6 or WIllwood, but I bet the information would help others, regardless of rim type.
SGTCONGO,
