What is the best way to tighten up loose door panels on C4?
The previous owner didn't address this issue either, more worried about performance and racing then interior work - but hey! My question is that the door panels are loose and seem to pull out if you try to close the doors. I am assuming that it just missing alot of plastic fasteners, but I don't know for sure. Can someone tell me if this was a common problem with C4s, and where a resource would be to remedy this annoying issue!
W2F
W2F
Re: What is the best way to tighten up loose door panels on C4? (WAY2FAST)
Howdy,
I have fixed this on my 87 by buying some of the metal "Armrest savers" . They replace the plastic insert where you grab the armrest to close the door. Helped alot!
Also the bottom of the door panel is held on by typical interior screws into plastic bathtub nuts. These nuts can be removed and turned around so the screws will cut into an unused part, or you can get new ones at most auto parts stores.
Also helps to get some new screws like you see in the line of "Help" parts at Parts stores. Some longer ones for the armrest savers helps alot.
If you just pull a door panel off I think you will see clearly what the problem is.
MIKE
MIKE
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: What is the best way to tighten up loose door panels on C4? (Mike_87conv)
:cheers: Mike, you have mail
hi,if you pull your door panel apart, do yourself a favor and go to any good body and paint store and buy a box of the plastic bathtub nuts ,a box of 50 only cost me 7.00 and change and it made a big differance on the fit of the door panel.good luck,greg84
Re: What is the best way to tighten up loose door panels on C4? (greg84)
If it's floppy and loose at the top when you close a door, then you're probably looking at buying a new door panel. The molded plastic retaining rim at the top of the panel just breaks with age, losing chunks of material that used to hold it tight at the top of the door. I know, both of my door panels are flopping.
At about $500 each, they're a long-term project for me. And I'll figure out a really good way to reinforce the new panels, and always close my doors gently.
