Spark Plug Wires for '96 LT4
This is in regard to a '96 CE with LT4 and ZF6...
What's a good replacement set of spark plug wires? I see lots of recommendationsa for Taylor, but what set number? I'd like to go with 84225's, the 8.2mm set, but like to know about fit. Don't want to have grind out my looms or anything like that. Anyone used them? Should I just go with the 7.mm's...74225's? What's your experience? Other brands? I'll listen...
Thanks!
Thanks!
racerseks (08-27-2018)
I'm also looking for a new wire set. I'd like to have red wires for the stock look but the Ac Delco is close to $200 for the set. Are there any other brands that has red wires for the LT4?
Thanks!
Thanks!
if you have headers , 8.2 mm won't fit. 7 mm is a tight fit . I purchased a closeout set of Standard ignition wire from RA FOR $12. Glad I did as 2 wires burned through on the headers(even with custom looms) purchased 2 generic 7mm wires, all is good..had they been oem red wires I would have been pissed.
Has anyone used the 84225's? Is everyone else using the 74225's?
I used the red Taylor 8mm on my 96 LT1 and used all the factory looms and holders .. Itwas a pain,,as they are a tight fit.. But was able to get them all in .. They look very good
racerseks (08-31-2018)
