Coolant temp when parked and engine off?
Old 08-29-2018, 12:28 PM
LS1951
4th Gear
LS1951's Avatar
Default Coolant temp when parked and engine off?
Hey guys. Just picked up a 1988 Callaway Twin Turbo. The car runs and drives great but coming from the Porsche world, the coolant temps shocked me at first! After some research I now know that these cars can run in the upper 230's on a hot day. My question is, what's normal after the engine is shut off? First thing I noticed was that all the fans turned off when I turned the ignition off. There's no way this is normal right?? Temps jumped up to 265 so I turned the key back on and let the fans run for a while. 265 cannot be ok right??
Old 08-29-2018, 12:33 PM
bjankuski
bjankuski's Avatar
The fans turn off when the key is turned off, that is normal. The other issue of the temp climbing when the engine is off is normal. It is called heat soak and since the water pump is off when the engine is off running the fans will not cool the engine and only wear down the battery so turning the fans off at key off is normal.
toddbvanslyke (09-01-2018)
Old 08-29-2018, 01:21 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
It if were me Id upgrade the cooling system to a better radiator/fan setup, use a 160 stat and lower temp fan switch so it never gets that warm in the first place.
Old 08-29-2018, 02:18 PM
bjankuski
bjankuski's Avatar
I agree, with that!
Old 08-29-2018, 04:56 PM
TerryOlson
TerryOlson's Avatar
I don't have a twin turbo, but I installed a 180 thermostat and a lower temp fan switch from Corvette Central (on at 190, off at 175 I think). I'm not seeing any more than the low 200s on a 90 degree day idling in traffic with the AC on. The stock fan switch on mine is set to cycle the fan at 238 degrees - way too warm for my liking because it means temps in the 240s. My original interest in lowering engine temp was to resolve a hot-restart issue that I was having. That's a thing of the past as well.
In other threads I've read that the fan switch can be reprogrammed in the ECM of later cars but I don't know what year this became an option.
Old 08-29-2018, 07:52 PM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
That will cool of radiator coolant, not the engine's. You simply need to remove the radiator and clean out the fins properly. That will cool things off a lot
Old 08-29-2018, 08:19 PM
LS1951
4th Gear
LS1951's Avatar
Thanks for the info guys. I think I’ll change the temp switch and thermostat to lower the temps as suggested.
Old 08-30-2018, 07:03 AM
ex-x-fire
ex-x-fire's Avatar
Does it get to 230 going down the road? It shouldn't.
Old 08-30-2018, 07:08 AM
LS1951
4th Gear
LS1951's Avatar
No, just in stop and go traffic during high 90 degree days. Although once it gets up there it tends to stay pretty hot even once I get going. 220’s
Old 08-30-2018, 09:06 AM
Cruisinfanatic
Like I said. Chances are your radiator is plugged up. Just needs to be cleaned. Lowering the thermostat will not change anything. Putting a lower temp switch is a band aid.
Old 08-31-2018, 07:09 AM
kenmohr
kenmohr's Avatar
tHERMOSTATS DO NOT LOWER TEMPS. tHEY ARE DESIGNED TO GET ENGINE WARMER SOONER.
FASTAZU (08-31-2018)
Old 08-31-2018, 07:16 AM
bjankuski
bjankuski's Avatar
yes and no, they will warm an engine up faster and keep it cooler as long as the rest of the cooling system can do its job correctly. As stated by the OP he said lower the t-stat and turn the fans on sooner. As long as the system can keep up the car will run cooler.
Old 08-31-2018, 11:21 AM
BillDurant
BillDurant's Avatar
https://www.rockauto.com/en/catalog/...,radiator,2172
are these appropriate for the 89 6 speed ?
Amazon Amazon
Or this one ??
Old 08-31-2018, 11:47 AM
FASTAZU
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I agree make sure the radiator is clean, turning the fans on sooner is the best way I have the stock 195 thermostat but have my fans set to both on at 210 off at 205 never see temps over 210. 200 while moving. I also always open the hood after a drive just to help let the heat out.
Old 08-31-2018, 04:42 PM
Cruisinfanatic
His problem is not the thermostat and changing it to a lower one won't fix it. The car runs hot
Old 08-31-2018, 11:09 PM
bjankuski
bjankuski's Avatar
Exactly, Make sure the system is operating as it should so it can extract as much heat out of the system as possible so he can keep the water temperature down to 200 degrees or less. That means make sure it is clean and then program the fans to come on at 200 degrees and off at 195. This is a turbo car, keep it cool if you can.
Old 09-01-2018, 07:02 AM
kenmohr
kenmohr's Avatar
Thermostats do not control high temps. If that was a true theory just pull the thermos out. There is another explanation for over heating.
To Coolant temp when parked and engine off?
Old 09-01-2018, 07:38 AM
bjankuski
bjankuski's Avatar
If the cooling system has the capacity to remove more heat from the car then it generates then the thermostat does control the high temperature of the system. In this case it is not doing that because either the system is not running as it should be and needs to be fixed, it might be dirty. Also the stock fan settings are 228 and 238 so it will not run cooler then that in town or wherever the airflow is low. The OP wants the car to run cooler so the suggestion is to clean the radiator, turn the cooling fans on earlier and run a lower temp thermostat. See where it runs after that and make changes as necessary. I would suggest a 180 thermostat and 195 on and 190 off fan settings. After those changes if the car will not run at 180 on the highway and 195 in town the radiator would have to be changed to get the car down to the thermostat setting. This is a turbo car, keep it cool.
Old 09-01-2018, 07:45 AM
fake
fake's Avatar
Take it to ct and have Callaway go threw it before you blow the motor! If you are not a mechanic and you have a no1 car why take the chance.?
Old 09-01-2018, 12:59 PM
Cruisinfanatic
All cars do. Thermostat has ZERO input on how hot it runs. If the car is running hot because of plugged radiator, the lowest temp thermostat put in the car won't change that
Quick Reply: Coolant temp when parked and engine off?
