instrument cluster reading to low
Looking for some help with my 87. my oil pressure is stuck on 80 my oil temp always reads low. my voltage is hanging around 9.8 and my coolant temp is around 128. car is running fine I don't believe it's a motor issue just something in the wiring or cluster. any help on what to check would be much appreciated. no luck searching on the web
thank you
thank you
