12 volt air pump on Opti Spark ?
Hello to all. I have a 1993 LT1 , One quick question , Has anybody used a 12 volt air pump to pressurize the opti spark ? this way it gets fresh air and keeps all contaminates out . Positive pressure hose to the Opti and Vacuum hose side from the Air filter case. Just have to find a live 12 volt after the switch. ( any suggestions ? ) Thanks Here is a link to the pump i might try. https://www.ebay.com/i/163050831142?chn=ps
I haven't tried to put a gen 2 cap on a gen 1 opti. I saw someone modified a gen 1 cap by drilling vent holes and connecting it like a gen 2. After cap is vented I don't know there will be an advantage to the air pump.
Live well,
SJW
Be aware that you can't bolt a Gen 2 unit onto your engine. The camshaft drive coupling arrangement is different. You can, however, add the Gen 2 active venting to your Gen 1 distributor. Search the archives here for posts about how that's done.
Live well,
SJW
Live well,
SJW
Petris makes a modified spline Opti with all the accessories to install it. It uses the break booster vacuume port off the intake and a port aft of the MAF. I would not use a pump.
I rebuilt my Opti spark and installed the Vac system , WoW what a difference . much nicer on slow pedal control. The main Question to this post was has anyone done the positive pressure on the Opti. and the Answer is nobody has . Thanks Y'all back to the Shadows i go.
Location: Las Vegas - Just stop perpetuating myths please.
But I have met a former LT1/opti owner that used a small CO2 cartridge on his Opti. Said it worked great for him but I don't see how a small cartridge could last very long. Well as far as that goes any positive pressure system would be an experiment as air pump life would always be in question.
Good luck and please let us know if you find something that works.
Pro Mechanic
All of the air in that system is filtered by the air filter. Only way you're getting contaminates or water in there is if your air filter is removed and you're going deep river fording.
Pro Mechanic
Someone did. What's that got to do with the venting systems that we're discussing in this thread?
More BS as usual is right. YOU said:
"I'm suspicious of the vacuum system drawing in contaminates (like water)"
I replied and said that on the vented system, all the air used for the venting is filtered air. Meaning; how ya gonna get water and contaminates in there?
So now....what are ya doin' Cardo? You're arguing just to argue again. Just like you always do. The type of system you choose for venting's got nothing to do with dumping water on the opti from a blown hose. IDK why you brought that up, other than to argue again. The factory system uses filtered air specifically so it doesn't get contaminates into it. IOW, "engineering" your own fish pump system is pointless for the reasons you listed (contamination) and won't accomplish anything that the factory system doesn't already accomplish.
It takes you 4 paragraphs to tell us your butt hurts. And we can read you don't understand how a positive pressure system can work.
Have you found pyschological help yet?
Pro Mechanic
Hey Cardoooo, That's OK with the insults. I "get it"....it's what people do when they're wrong, can't admit it and don't have the maturity to handle it better. Best of luck to you and you fish-tank-opti.
A vented opti with vacuum drawing in fresh air is never under significant negative pressure inside the cap. The point is to move fresh air through the system, not to pull a vacuum (i.e. pressure differential) on it. The opti internals are wide open to the atmosphere via the fresh-air supply tube that connects to the intake snorkel. Therefore, the vacuum moves air through the system but never puts significant pressure differential on the system. It won't "draw in moisture" through the cap and seals. By the same token, trying to move air through the system with positive pressure via the outlet of a fish tank pump is going to move air but not create a pressure differential. The system will be equally (in)vulnerable to water as with the OE vacuum system.
BTW, the reason the vented opti is important isn't because of moisture. It's because it helps prevent ozone buildup in the cap, which otherwise will cause corrosion and poor distributor performance. If your seals are good on the cap, water isn't getting in. If they are bad, water can get in regardless of venting or not.
Ha, ha, ha. Vacuum moves air but doesn't never puts significant differential pressure on the system? More imagination engineering again. My car pulls nearly 18"Hg vacuum which is close to 9psi. The dynamic force of air moving at 100mph is only about 0.5psi. You are just full crap again. I wouldn't bother to even respond other than to warn others.
As usual I get 2 trolls on one thread. I think they're linked together - some type of bonding. :-
It's the same story for the opti: it has a fresh-air opening that's the same size as the suction port. Ergo, there's nearly no restriction against which the vacuum port can exert any force (negative pressure, aka vacuum). So it moves air instead, which is the whole point of the vent system on the later optis. This isn't exactly rocket science here, cardo. But if you don't believe me, prove me wrong:
- Take an opti that's out of the car and rig up vacuum gauge. It won't be hard: just attach a T fitting to some vacuum tubing off the fresh-air intake side, and attach the gauge to the extra branch.
- Now put some tubing on the suction nipple and attach that to a vacuum source: a/c vacuum pump, fish tank pump, Mity Vac, whatever.
- Now with the non-gauge end of the T on the intake open, see how much vacuum you can actually pull.
Ha, ha, I don't drive at WOT. At normal road speeds I have at least 12" of vacuum. And I know this because I have a manifold vacuum gauge mounted on my dash. And I recall it's tee'd into the same port the opti uses as my opti is a conversion from early non-vacuum vent to late vacuum vented opti as I run a late model opti and timing cover on my early model opti car.
So you want measure vacuum on the fresh air side side? How stupid! Of course it will near atmospheric or it should unless the intake duct has restriction. You don't even know how your intake works in front of and behind the throttle blades! Your ignorance is proven here. Yet I'm sure you will continue to run your mouth until it becomes another topic like formula engines.
Shut up and go away!
