L98 PCV right valve cover parts?
Finalist 2020 C4 of the Year - Unmodified
The elbow and valve cover connector on the right side of my '87 L98 have turned into jelly and are leaking.
Haven't found a replacement, other than some Dorman "buy and see" stuff online.
Anyone noted source or part numbers for these?
this one?
https://www.amazon.com/dp/B008Y9EPLO/ref=cm_sw_r_cp_tai_TNUJxbJXVJRX7
kael (09-12-2018)
Having the correct name or number for a part sure makes it easier.
Even better is putting the dang number on the part!!
Time to make a workaround I guess.
Related:
https://www.corvetteforum.com/forums...ody-elbow.html
Related:
Related:
Related:
More info gathered, from CF thread I mentioned, Dorman #47054 is an acceptable replacement and costs under $3 at Rockauto. This doesn't show the
Proper name of part inserted into valve cover: PCV (Positive Crankcase Ventilation) Connector
OEM ('87):14082445
Still chasing the elbow. Think I may go with the easy fix, a zip tie.
Proper name:PCV Vent Pipe Connector Elbow, Right
OEM:14082446OEM:14082446
OEM ('87):14082445
