How to install upper control arm bushings?
I'm trying to replace my bushings with Energy Suspension poly urethane bushings. I am having trouble getting the bushings back in. As i am pushing them in, they swell and buckle and just refuse to slide in. I wrapped them with hose clamps to get them within 1/2 inch, but I can't get them that last little bit. What did ya]ll use?
Agree with the above post, I've done these on other cars and a press with plenty of grease was always a must and they were still hard to press in. I also found that temperature made a difference.
I did the press option also. you need to brace the A arm as shown above or you will bend the crap out of it. I used Energy Suspensions grease, its extremely tacky, wear gloves. That **** sticks to everything
Yes that is what happened to me, I installed bushings on one arm on a high 50 degree day and the other arm when it was around high 30s and the bushing split on me. It seems that they are a bit more pliable when it is warmer out.
I used the process in post #2. I also used a stainless steel hose clamp to help get the bushing started. It was like described above and every thing had to be straight to get them in.
Do grease the bushings with lot of silicone assembly lube. I purchased a 4 oz extra tub of silicone grease with the front and rear bushing sets/
