1994 won’t crank/stalling and shutting off after cranking
Old 10-13-2018, 09:41 PM
Farrishayes23
Cruising
Farrishayes23's Avatar
Default 1994 won’t crank/stalling and shutting off after cranking
I just got a 94 w/ new alternator and valve covers. Everything was running good. Got it from my grandfather. Now it is stalling when trying to crank and when I do crank it it just cuts off after 2 minutes. I was driving and it shut off on me as well. I felt a pull on the highway then saw the engine soon light come on. Has anyone had this problem or know a solution?
Old 10-14-2018, 06:01 AM
Drifter36
Drifter36's Avatar
It could be a number of issues so I suggest you check to see what codes are being generated. A failing opti spark can explain a number of your symptoms but it should generate some codes. Good luck.
Old 10-14-2018, 01:52 PM
Farrishayes23
Cruising
Thanks @Drifter36 i appreciate it.
Old 10-15-2018, 07:40 AM
fake
fake's Avatar
Did you pull codes? Any H codes? How many mileage on beast? Any repair records?
Old 10-15-2018, 11:06 AM
Farrishayes23
Cruising
81,000 miles
I trying to get it looked at.
Drove it from Alabam to Atlanta, Ga though about 3 hours because of bad weather and it drove like a champ. Go to Walmart and it cuts off on me.
Old 10-15-2018, 10:55 PM
Farrishayes23
Cruising
Mechanic says it’s the ignition switch, ought to be getting it bridged tommorrow. Though it cranks on a dime on 3rd or 4th try and runs like a champ.
Old 12-09-2018, 07:46 PM
Farrishayes23
Cruising
It started back acting up, so back to work with it I go.
To 1994 won’t crank/stalling and shutting off after cranking
Quick Reply: 1994 won’t crank/stalling and shutting off after cranking
