89L98TPI's new 434 SBC
Old 10-17-2018, 01:56 PM
rklessdriver
CF Senior Member
rklessdriver's Avatar
Recieved 185 Likes on 154 Posts
Originally Posted by ctmccloskey View Post
Thanks for the pictures, that is a beast and should make any Corvette happy.
Do the Vertical Gas Ports really help these motors seal their piston rings better? Is there a limit to ho much compression they can handle? I had never seen them before, I must be out of touch or just getting old....
Thanks again!
How much gas ports help the ring seal really depend on the ring package used. In this case (.043" top ring) yes they do help the top ring seal better. +10-15HP in some extreme cases.
There is no limit to the compression they can handle.
We use them in as many applications as we can get the customer to pay for the expense honestly... ring seal is HP. Sometimes we use vertical like you see here and sometimes lateral. Vertical gas ports are more efficient but typically used in short duration engines like drag racing and endurance engines typically use lateral gas ports. This "application dependent" use is due to carbon build up on the piston top which can block the vertical gas ports, however with this one being set up for E85 fuel, I felt it would be fine with vertical ports on the street.
Will
rklessdriver is offline
ctmccloskey (10-18-2018)
Old 10-17-2018, 04:12 PM
Pwnage1337
Pwnage1337's Avatar
Recieved 41 Likes on 37 Posts
Originally Posted by 89L98TPI View Post
Coming soon...
Looks slow dude, gotta step your game up
Lmao! Awesome work guys.
Pwnage1337 is offline
Old 03-26-2019, 09:53 PM
89L98TPI
CF Senior Member
89L98TPI's Avatar
Recieved 7 Likes on 5 Posts
Update... Alternator and Vacuum pump mounted. About ready to install for final time.
Stock Motor mount "towers" and stock rack and pinion mounts cut off Kmember... Pinto rack mounts welded on and new steering shaft made to connect. Half @ss paint job in the cold....
To be continued....
89L98TPI is offline
Old 03-27-2019, 10:36 AM
dhirocz
CF Senior Member
dhirocz's Avatar
Recieved 3 Likes on 3 Posts
Daffy says it all.
dhirocz is offline
Old 03-27-2019, 07:15 PM
STEVEN13
CF Senior Member
STEVEN13's Avatar
Recieved 28 Likes on 26 Posts
Looks great! The front clip looks like a race car with the engine plate and Pinto rack-Very cool!
Can't wait for the track results.
Steve
STEVEN13 is offline
Old 03-29-2019, 05:13 AM
88BlackZ-51
CF Senior Member
88BlackZ-51's Avatar
Recieved 9 Likes on 6 Posts
What do those heads flow? Nice build......I know these are never cost effective.
88BlackZ-51 is offline
Old 03-29-2019, 05:46 PM
rklessdriver
CF Senior Member
http://speierracingheads.com/v270pf23ordm-250cc.html
Will
Old 03-29-2019, 06:58 PM
tpi 421 vette
CF Senior Member
tpi 421 vette's Avatar
Recieved 23 Likes on 19 Posts
Nice work Will
tpi 421 vette is offline
Old 03-29-2019, 09:24 PM
1985 Corvette
CF Senior Member
1985 Corvette's Avatar
Recieved 52 Likes on 40 Posts
Can't believe I missed this thread and Jesus the intake ports and valves in those heads! A legit nitrous motor, I love it. I wish I was your neighbor, Will...
1985 Corvette is offline
Old 03-30-2019, 02:06 PM
383vett
CF Senior Member
383vett's Avatar
Recieved 682 Likes on 507 Posts
Nice build Will.
383vett is offline
Old 03-30-2019, 10:12 PM
l98tpi
CF Senior Member
Support Corvetteforum!
l98tpi's Avatar
Recieved 40 Likes on 39 Posts
NICE BUILD
l98tpi is offline
Old 03-31-2019, 12:52 PM
89L98TPI
CF Senior Member
89L98TPI's Avatar
Believe it or not I probably had more in building the old 383 then I did the new 434.... Live and learn.
89L98TPI is offline
Old 03-31-2019, 06:33 PM
  #33
dizwiz24
CF Senior Member
Recieved 76 Likes on 73 Posts
Looks beautiful ! Thanks for sharing !
You cant go wrong with any of Will’s builds !
dizwiz24 is offline
Old 04-03-2019, 08:00 PM
  #34
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
Recieved 366 Likes on 323 Posts
Just dam
1993C4LT1 is online now
Old 04-09-2019, 08:24 PM
  #35
89L98TPI
CF Senior Member
89L98TPI's Avatar
Tight fit. How did GM manage to fit all the stuff they did under there...
89L98TPI is offline
Old 04-09-2019, 09:21 PM
  #36
C409
CF Senior Member
C409's Avatar
Recieved 124 Likes on 116 Posts
..... Did I miss the dyno results ? I went through the entire thread again but didn't see anything about the output …..
C409 is offline
Old 04-10-2019, 04:33 PM
  #37
89L98TPI
CF Senior Member
89L98TPI's Avatar
Didn't wanna deal with the headache of pulling all the EFI stuff from car to make a few pulls on engine dyno. We will be at the drag strip shortly and let the time slip do the talking. 9s NA should do the trick!
89L98TPI is offline
Old 04-10-2019, 08:31 PM
  #38
383vett
CF Senior Member
383vett's Avatar
Good luck!
383vett is offline
Old 04-10-2019, 11:10 PM
  #39
1993C4LT1
CF Senior Member
1993C4LT1's Avatar
This, I like.
Old 04-12-2019, 09:51 PM
  #40
C409
CF Senior Member
C409's Avatar
….. Sounds Great ! … Keep us posted … what does your car weigh ? …..
C409 is offline
Quick Reply: 89L98TPI's new 434 SBC
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
