The dome lights won’t shut off
The dome lights won’t shut off.the head light dimmer switch is not the problem.
I’ve removed all the plugs from them.checked for a draw.i have a 4 amp draw until I remove the courtesy light fuse.the the draw goes away.
Possible dome light module?
Where is it.
Where is it.
Another thing to check is the door locks. When the round key is inserted into the lock cylinder and turned to unlock the door, it turns on the interior lights. If the lock cylinder is not returned exactly to the vertical position the lights will remain on. Guys with PKE may not have experienced this.
