L98 ran out of gas drove 300 mi. Now I got a misfire..help
My 91 61 thousand miles.l98 all original. Ran out of gas .filled it up.ran a full tank thru.it.30 mpg at 75 mph.no trouble.real fun drive 150 mph a few times on hwy 5!!!filled it up again now I got a misfire.compression is good no clanking or internal noise.all plugs good.wires cap rotor replaced.no fouled plugs tan and clean.still missing on one mabe two ...?going to do fuel filter now with a k&n filter.what else could my black beauty need to solve this?
When does it misfire? If you disconnect iac and set timing connectors, disconnect injectors try to determine which cylinder is misfiring.
Maybe you hurt a valvespring on your 150 mph run.
