1986 Corvette will not stay running - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 11-04-2018, 09:27 AM
EdAStevens
Junior Member
Default 1986 Corvette will not stay running
Need help in identifying this problem.
Someone stated it is because of the security system?
Cat will start and run then shuts off. Fuel Pump is Ok, fuel Pressure Ok - no spark?
It has new distributor, wires
Any ideas?
Thanks Ed
EdAStevens is offline
Old 11-04-2018, 10:26 AM
VikingTrad3r
CF Senior Member
Support Corvetteforum!
VikingTrad3r's Avatar
its not vats, fuel pressure with key on, while cranking, while running poorly, after it dies.
test for spark by either arcing somewhere downstream of the dizzy (wear gloves!) or put a timing light on and see if there is light.
once thoseareanswered, then whats The history on the car? For example were you able to use it just a week ago fine and then this just happened? Or did you just pick up this project? Depending on what the answer is will direct from here
VikingTrad3r is online now
Old 11-04-2018, 08:24 PM
playsdixie
CF Senior Member
playsdixie's Avatar
does fuel pressure die with the car?....pump only runs 2 sec......then oil switch takes over......
playsdixie is offline
Old 11-04-2018, 11:10 PM
C409
CF Senior Member
C409's Avatar
.. If the ECM does not see active ignition pulses from the Ignition Control Module , the engine will start but will not run . The ECM is thinking that it didn't start Is your new distributor correct for Electronic Spark Control ? The ICM should have 7 pins the ICM may be defective ..
C409 is offline
Old 11-05-2018, 10:05 AM
aklim
CF Senior Member
aklim's Avatar
You sure? I disconnected my oil pressure switch. Got 0 psi. It seemed to start and run.
aklim is offline
Old 11-05-2018, 10:09 AM
VikingTrad3r
CF Senior Member
my understanding is that ops is reverted to only if fpr fails to activate pump.
interesting test would be to disconnect the fpr, and the ops, see if it starts and keeps running.
Old 11-05-2018, 10:24 AM
aklim
CF Senior Member
aklim's Avatar
What has the FPR (Fuel Pressure Regulator) got to do with it? You disconnect it and the pressure goes to max.
I wonder about this. If he has a gauge hooked up to the fuel pressure regulator port and the ignition shuts off suddenly, wouldn't the pressure hold (assuming the system is good) for a few minutes since the injector pulses stop suddenly? Makes me think ignition module at that point.
aklim is offline
Old 11-05-2018, 11:00 AM
VikingTrad3r
CF Senior Member
Ak....fpr is also fuel pump relay....
Quick Reply: 1986 Corvette will not stay running
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
