Paint my gas tank?
Paint my gas tank?
Hello everybody,
I just pulled my gas tank from my 1985 Corvette. It needs the seam where the fuel pump goes in to be repaired, welded. The mechanic at the shop said I should paint the tank. I have heard that painting gas tanks is not a good thing. Anybody have a definite answer. Yes or No
Thank you
Thank you
If your 85 is like my 85, it has the plastic bladder in the stock tank. This is a problem because they leak and rust from beneath.
I wouldn't pay a nickle to try and repair one of those.. I'd trash it.
Here's what happened to mine and the replacement was about two hundred bucks, I think. I painted it. Seems fine.
Be sure to use good fuel hose with the proper rating!
https://www.corvetteforum.com/forums...-gas-tank.html
Red 91 (12-01-2018)
If you guys think yours were bad - look at the one from my 1994!
I will say this - it never leaked. The bladder on the inside is very thick rubber, maybe 1/4 inch thick or so. Of course the straps barely kept this thing in place in the car. It was a relief to swap it out and not have to worry about it anymore. Gotta love cars from the northeast (this one came from PA originally)
I painted the replacement (a nice clean salvaged OEM tank from ebay) with roll on truck bed coating.
