can idle speed on my 95 be adjusted?
And gaskets. Don't reuse them or condoms either
Idle Air Controller. It's a small stepper motor that controls the idle air passage. The computer uses it to control idle speed by varying the idle air opening. You'll find it screwed to the bottom side of the throttle body.
temcgregor (01-09-2019)
It's about right for cold startup idle. But for a stock engine that's already warmed up, yes that is high. I don't know which engine you have, but as a reference, on a stock LT4 the computer targets 1050rpm at cold startup and it tapers down to 700rpm when warmed up. And that engine probably has the most radical (but not very) cam of any C4. So an LT1 or L98 might even target 650 or 600.
