AutoXray AX7000 manual.
Cruise-In II Veteran
Just received an Autoxray AX7000 and it comes with only Quick Startup Guide. The Operator's Manual used to be downloadable in PDF but seems to no longer exist on line.
Does anyone have said manual in PDF form and would be so kind as to provide a copy?
Location: Las Vegas - Just stop perpetuating myths please.
I have a much much older model autoxray but I found a user manual for the autoxray EZ SCAN 6000 that should be very similar to the AX7000 but doesn't use SD cards or have USB ports of the AX7000. What I'm saying is the 6000 buttons and menus should be very similar to AX7000. Take a look: https://www.northerntool.com/images/...als/338956.pdf.
Also you probably found the AX7000 sales brochure but here it is if you didn't: http://www.etoolcart.com/manual/lr_pdf_136.pdf
I look at my autoxray scanner next time I get to storage but I'm sure its way older unit than the AX7000 or even the EZ SCAN 6000.
Hope this helps.
Hope this helps.
Actron took ownership of Autoxray so you may want to contact Actron technical support or customer service. https://actron.com
Good luck.
Good luck.
I can see why they made it available as a .pdf instead of including a hard copy, i.e. 271 pages. Got 'em all printed last night, so 136 sheet volume.
Thanks again for the help.
Hooked up the unit today onto the '88. Got a complete engine parameter scan.
BTW, there was no idle issue caused by the tool, as some had reported on Amazon.
Very simple to set up/use and it records all available parameters, as advertised.
It's this real-time running data log that I was seeking.
Congrats! Its important you get a good data file of your motor before you make any modifications or it starts to run poorly. You are past the first step to tuning your motor. And looking at your profile I expect you will soon be teaching us how to tune your corvette.
Since I owned my first 35th Anni in 2000 I used an old AutoXray to trim/trouble-shoot that engine. Eventually that scanner crapped out about the time I stopped tracking the Vette.
It took me a number of yeas to locate this scanner. I am pleased to report that it does an excellent job.
Thanks for the vote of confidence...
