Installing Melrose Headers on 1984 Corvette
@85WHITEZ51 Okay. Makes sense. I have the driver's side manifold off now and the only problem I'm having is getting the old gasket off the block. Other than that, everything is going well. I'll post back here when I'm done.
4th Gear
I just finished installing Melrose headers this past weekend on my 84. Pretty much what everyone else has posted. Remove plugs and dipstick. I have a reman starter and agree with putting a shield on it. Make sure you connect all the starter wiring and put a reflective/heat reducing sleeve on those wires as well before installing the headers as it's a pretty tight work area if you don't. One other thing to watch is the transmission cooling lines as I had to loosen and move them a bit as they were touching the header on the passenger side. Other than that, easy!
@Mkimbler Did you end up needing to go to shorty plugs? Also, 2 stupid questions. How do you know when all the gasket is scraped off the cylinder head? I'm guessing it's when there is no more black but I've never done it so idk. Also, which side of the gasket goes against the cylinder head? I'm guessing it's the more "unfinished" looking side of the gasket. Thanks for the help. I appreciate it a lot.
4th Gear
This is an 84 so the gains might not be as good as the TPI ones. So to justify the cost, what exactly does the OP want to achieve to justify the $1000+ expense?
I have the complete Melrose kit on my '85 and they are, hands down, the easiest headers to install I have ever used. The entire kit fits like a glove, just mock it all up then align everything and tighten it all down. Removing plugs is a good idea, like 383vett said, you will break a few doing the R&R. As far as a mini starter, the Melrose headers will fit around the big starter nicely, but getting the starter down and out of the car is a real pia so I recommend a mini just for ease of starter maintenance. I had Hedmans on my car first and while they are a good header, the Melrose kit is far superior.
@aklim If I had the money I would do full bolt-ons and have the engine rebuilt and make it a 383 stroker. Since I don't have the money to do that, I'm just making sure that all current mods will help me reach my end goal. Also, if I'm going to do something, I want it done right and I don't want to waste my time installing a cheap product.
@Midnight 85 Thanks for the info and I'm glad they fit well. I'm almost done with driver's side and I'm ready to remove the passenger's side. What did you do with the A.I.R. hookup that went back to the cat?
I still think it's worth it. You wont gain a lot of peak HP or TQ but you should see a gain across the powerband. It will improve the efficiency of the engine as well and as is good foundation mod especially if you plan to do anything down the road.
#33
@aklim I'll never have enough money to mod the '84 to its limit so its power eventually being limited by the fuel delivery system ins't something that bothers me. I just want to have a nice car that sounds good and is enjoyable in the corners.
#34
If you want it better in corners, it probably wouldn't take much to mod the suspension. Not sure what to say about "sounds good" since I am not into sound and would probably want it to be as quiet as an electric motor to sound good to me.
#35
#36
Thing is you cannot change the ECM program so you are going to have to keep the parameters stock. IOW, increase in air flow will have to be met by fuel flow so that the ECM thinks it is within spec. That is going to make it harder. I guess my question is whether it is worth it from the standpoint that you will have to be very careful in what you do and take more time than say with a L98 or LT1 or LS series engine. If it were my car, I'd either live with the system the way it is, (there is enough power for the corners), and make life easier on myself or get a different car altogether that will be easier to mod. So if you aren't hung up on this particular car, it makes things easier since the car is stock and you can sell it easier.
Or if you want to go crazy there is the EBL flash route then your options are endless. If you're planning on building it, you gotta pay to play as it isn't cheap to do right.
#37
@84 4+3 I was planning on getting the Renegade intake before I go to college next fall.
@aklim I thought the ecm could be changed. I've seen people say they got one from pcmforless and I've considered this one from EM Racing. That link is technically to their old website but it's on their new one as well I believe. I've called and talked to them and they are fully aware that the '84 has the L83 even though the L98 is the only one listed.
@Midnight 85 If you plug the hole at the cat, which I won't have, do you just plug the other end as well and leave the pump in or just let the little pipe hang open?
Thank you all once again the help. I'm done with the driver's side and am waiting on a few parts before I install the one on the passenger side. I just finished cleaning off the old gasket on the head today so I should be done within the next week.
#38
#39
@84 4+3 I could but I'd rather buy it and return bad ones at no cost to me than port a stock manifold, which I can't do. I think @Buccaneer could help me set up a pretty good CFI build that would most likely include a Renegade intake. Outside of the renegade intake, @383vett or @Tom400CFI could probably provide a lot of good info. Idk what exactly I'll do yet, but the time for me to do other mods has yet to come so I'm not going to worry about it. I'm just going to enjoy my exhaust for now.
#40
