All power cuts off when the key is turned..
Hey Guys, been a min since I posted but I'm having a very very weird problem on my LT4. When I go to turn the key and start the car, all the power is cut off when I turn the key to start. All power is cut, no interior lights, no dash, no power to anything. It remains this way for about 1 min, then power returns and I can start the car. To me it seemed like a grounding issue, when the starter demands amps/current there is a ground that is bad causing this issue. I checked all the grounds and completely removed and cleaned the main ground for the ECU located just above the oil filter housing. After cleaning all the contacts I went to start the car, same issue. So now that I have cleaned the contacts and verified that my batt (yellow top optima) was in good condition with 12.53 volts, that do not drop when I start the car.
Im fresh out of ideas, but I know there are some seriously smart guys on this forum and am hoping someone may have experienced this before? or could possibly help me out?
AgentEran (01-10-2019)
I think this is worth checking out, I did remove and reinstall the negative batt post. I checked the positive and it was tight, but this does not mean there isnt an issue. When I get home tonight I will remove the positive and make sure its right, bc I do have a spacer on it. I once had a pu truck that did this, and your post made me remember. Thanks!
It was the positive terminal on the battery. I have a couple amps for the radio, which necessitates the use of a longer side post bolt and a spacer, like this:
Well apparently this set up was a little loose on the battery side. Tightened it up and issue has ceased to be!
Thank you very much fellas!
