Bose speakers on 91 Vert
Old Oct 31, 2002 | 02:51 AM
Black ZR1's Avatar
Black ZR1
Default Bose speakers on 91 Vert
Speakers are scratchy sounding. Is this an easy do it yourself job? I need to pop off the speaker covers on the floor. Do they just pop off?
Old Oct 31, 2002 | 08:50 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Bose speakers on 91 Vert (Sensei Earl)
If your vert is like my coupe, then the answer is no. The speaker covers are part of the sill carpet. Remove the screws along the sill area and at the rear door jam. The entire piece from the foot well to the door jam comes out as one piece.
Old Oct 31, 2002 | 09:06 AM
Scoob's Avatar
Scoob
Default Re: Bose speakers on 91 Vert (Steel Blue 91)
Correct on the removal. Edit: if it is the one on the drivers side you also have to remove the seat bottom and then the plastic e-brake cover in order to remove the sill. I can take some digital pics of my service manual on this if you want. It's not as much of a pain in the rear as it sounds.
The scratchy sound is the amp on it's way out. It is a common occurrance. I just sent 2 of my amps out for repair. If you know about soldiering and capacitors this is a DIY job. Sadly I don't know that stuff so for me it is a checkbook job.
[Modified by Scoob, 8:07 AM 10/31/2002]
Old Oct 31, 2002 | 09:40 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Bose speakers on 91 Vert (Scoob)
Bye Bye amp or it could also be a blown speaker. Bose speakers are paper and foam. Very cheap construction and don't hold up well. You gotta open her up and see. Either replace the parts inside the amps, send it out to RadioJoe, or install an aftermarket system that was designed after Zepplin stopped touring. I believe there is the cap replacement operation detailed in the tech tips section. Let us know if you need more help.
Old Nov 1, 2002 | 11:28 AM
Scoob's Avatar
Scoob
Sensei Earl - did you get my emails?
Old Nov 1, 2002 | 11:56 AM
Black ZR1's Avatar
Black ZR1
I've been out.
Got them.
Thanks a bunch :cheers:
Old Nov 1, 2002 | 04:41 PM
Scoob's Avatar
Scoob
I've been out.
Got them.
Cool. Let me know if you need other pictures of anything. I currently have a front and a rear amp out for rebuild so getting pics will be easy for me.
Old Nov 1, 2002 | 06:42 PM
monkeyboylawyer's Avatar
monkeyboylawyer
Zeppelin. You are being to kind. They were touring into the eighties.
Try Hendrix. :)
To Bose speakers on 91 Vert
