c4 throttle body coolant cover
Cruising
1985 Vette. I broke the throttle body coolant cover and cant seem to find one anywhere. I can buy an entire used throttle body but not just the coolant cover. I can buy a brand new throttle body and the IAC valve that screws into the coolant cover but no one seems to sell the coolant cover. Surely I'm not the first to experience this problem. I've searched the forums and haven't found anything. Any suggestions? Thanks!
Do you mean to say the "Throttle Body Plate"??? The rectangular cover plate with six small bolts??? If so, there are many out there for sale online. Not sure what the "coolant cover" you talk about is.
Gene805 (02-10-2019)
Cruising
The throttle body coolant cover I'm talking about is on the opposite side of the throttle body from the throttle body plate. The IAC valve and 2 coolant line run through the coolant cover.
Is it leaking coolant? If it is the easy solution is to bypass the coolant lines for the Throttle body. Then there is no coolant in the Throttle Body any more and as long as if isn't leaking in unmetered air then you are good to go. You might even see a little performance gain out of it by not heating the air going into the engine.
You will see UP TO 10 HP would be my estimate if he did the bypass. The theory is nice but in real world application, if he did get anything, it would probably be so negligible that the mind would have to work overtime to imagine the gain. It will make it easier to access the TB though.
I agree Aklim. Any real HP increases would be real hard to quantify. There are a lot of non performance benefits such as not having to worry about coolant leaking from the throttle body and not having to make a big mess when you remove the throttle body for service. I can also tell you that the throttle body does stay A LOT cooler. When I have my car out at the races I find that I can safely touch the throttle body and not get burned. Before I did the bypass that thing would melt the skin right off of you. So it might be more accurate to say that instead of a performance gain you instead suffer less performance loss due to heat soak as you run the car hard in hot weather?
I would agree it would be cooler since the coolant might be about 200 degrees. So would it heat up the air by a bit? Definitely. How much? I really don't know since I haven't done the calculations for how much energy the warmer TB imparts. On the street, do I think it would make a difference? I don't think so since we couldn't feel even a hundredths of a second. On the track, if a thousandths of a second could mean a win or loss, I'd be so over it.
