1985 corvette help please
Old 03-12-2019, 12:52 AM
Mason123
Junior Member
Default 1985 corvette help please
Okay so, another probelm guys. I apparently suck with cars so, youíll need to explain in very much detail
now whenever I start up my car, it turns on but then instantly dies. Sometimes itíll stay on, but dies only when I hit the throttle.
The check engine light on.
Im suspecting the spark plugs so Iíll buy some on Saturday. Why not, right.
But could it be anything else? I put in a new fuel pump, and the wires are all good.
Only other thing is I need to fix the vacuum hoses because Iím getting like... I donít know... 11 mpg on average.
Also the the emergency brake doesnít work. I can bring it up and down but it doesnít like... lock in or anything.
I really love this car, actually itís my first car, Iím 17
what a perfect time to have one.
anyways any help is appreciated
Mason123 is offline
Old 03-13-2019, 12:34 AM
xrav22
CF Senior Member
xrav22's Avatar
First you will need to find out what the check engine code is. Google and you will find out all you need is a paperclip. Learn how to read codes.
Vacuum lines will not cause the car to die. Mine ran fine when I did not even know I forgot to hook a few up(exeption is ths brake booster).
When I got poor milage it was because a cylinder was down(injector plug was corroded) found it and running great again.
Good luck with the 85 but the code is telling a story.
xrav22 is offline
Old 03-13-2019, 09:37 PM
mtmvette
Junior Member
mtmvette's Avatar
You need to get a good manual for your car and read and study it.. Also, some basic diagnostic tools. To much vague information will only lead to much speculation and guessing. Learn how to obtain the engine codes, get a fuel pressure gauge, digital multi-meter, and maybe a power probe. If you suspect spark plugs pull one and check it. Unless I can verify and check to see if the ignition system is new(recent) I always change the basis out.Ignition cap rotor, ignition wires, spark plugs.
mtmvette is offline
Old 03-14-2019, 08:06 AM
KyleF
CF Senior Member
Yup, have to get that code.
There is no harm in replacing the plugs, but just throwing parts at the car is never a good plan. TBH, I have seen very few problems solved from changing plugs. Normally, fouled plugs are a symptom, not a cause.
KyleF is offline
Old 03-14-2019, 09:09 AM
vader86
CF Senior Member
vader86's Avatar
Pull codes first, if its from cold start it could be CTS related or injector issues, difficult to say, but need to know what the code is.
vader86 is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
