Do you use a "water wetter"?
Old 03-14-2019, 07:46 PM
CF Senior Member
Originally Posted by KyleF View Post
Awww... C'mon. You don't need to time vs Delta T. Just make sure you have it recorded on video. If you want to get an idea of what it will do, just fill your dishwasher cup with dish soap rather than the powder dishwasher soap. You will have suds on the floor in no time and you won't believe the amount of bubbles that can be generated. Just ask my college roommate
I would picture massive bubbles trying to escape to the overflow tank and the coming out of the vented cap.
My Viper ran hard down against it's thermostat too when on the highway or back country roads. It would even set in traffic for a good 5 minutes before it the cooling fan even kicked on.. but once it starting getting hot... it got hot. It would slowly creep up to 190, 200, 220 and so on by the factory gage It never overheated, but you could tell the engine was not happy about being that warm not to mention the heat soak to the interior as that heat filled the transmission tunnel. It is enough having side pipes, have that heat creap in would start to get uncomfortable on a hot day.
I replace the t-stat (Factory 180), made sure the radiator was clear of debris and blowed it out from the rear with compressed air, changed the coolant yearly and you could tell both fans function. I was told by fellow owners this was all just normal. So, I added some water wetter to just see. It ran just a tick cooler (again by factory gage) the summer I had it in. I estimate based off the gage, it was about 10 degrees cooler. Not much, but the stuff isn't all that expensive. Question the accuracy of the gage.. was it 10, 20, 30 or somewhere inbetween? I will say 10 as a conservative mark.
I do not use it in my Iroc or C4, neither seem to have issues with heat soak. It will only help. It won't solve overheating issues.
My college roommate went to do that too but atleast asked me before hand. I can not repeat what I called him because I would probably be banned on the spot. Lol.
Heat transfer is heat transfer... or the q is the q if you want to go that way. You can't change the heatransfer coefficient of water... but you can improve interface interactions... so yes a surfactant should help. Salt water has a lower heat transfer coefficient than straight water as does 50/50. So let us see what else in there. 2 alcohols and a corrosion inhibitor. The corrosion inhibitor accounts for less than 3% so it probably has no meaningful impact on heat transfer so we're left with the two alcohols. Well we can assume they also have a lower heat transfer coefficient. So what's going on here? Well, my statement as before, you're just marginally improving the interface... a better way to look at it is that you simply are improving the mixing... in the simplest sense.
And I am not stupid, I'd run it on a test apparatus in a lab. You can play temp readings in the car all you want but a change in cooling time is the same weather it's on a bench or in a car no? I'm not saying you should add soap... that's just dumb. But I mean if you want me to try it in my car, sure. I'll just make sure I add the deforming agent at the same time.
If you want a real lab test, I'm game. We can see and measure exactly what water wetter does compared to straight water and compared to water with soap. Just let me know. I need a day or two to gather all the pieces for the test. Just let me know.
84 4+3 is online now
Old 03-14-2019, 08:21 PM
Aardwolf
CF Senior Member
Aardwolf's Avatar
It would be interesting to see your test!
Aardwolf is offline
Old 03-14-2019, 08:55 PM
dizwiz24
CF Senior Member
Yes.
I use water wetter. Car is supercharged and I wanted every little piece of mind in cooling efficiency
dizwiz24 is offline
Old 03-14-2019, 09:47 PM
aklim
CF Senior Member
aklim's Avatar
I'm interested. Please record it. Any way you can test it with 50/50 mix of antifreeze as well under pressure? I'm real curious what you find. I have no doubt that there is some gain to be had. What I don't know is how little or how much. If all you have is a drop of a tenth of a degree, well, the only thing selling it is "It's pretty cheap so no big deal if it doesn't work.". OTOH, if it can bring down the temps significantly enough for a street vehicle, it will be very interesting. I've run the car with WW before in stop and go traffic with the AC on in summer but it still went up till the AC was shut off and I was baking. So if more will help, I'd be curious to put it in again.
aklim is offline
Old 03-14-2019, 10:52 PM
CF Senior Member
So running at pressure would have no effect... the only reason cars use a pressurized cooling system is to increase the boiling point of the water in it. In other words, heat transfer only depends on the conductivity of the materials and relative temperatures. I'll gladly try it with a 50/50 mixture though.
My plan is this:
tube and fin cooler.
Pump running at a specific gpm
Efan bolted directly to cooler
Ambient air temp monitor
Fluid heated to specific control temperature
Time required to reach a 75% reduction in water temperature
As long as air temp and fluid temp remain constant between tests, we should be able to measure time differences between all the tests and determine if there was a significant change in the overall removal of heat from the fluid. Plain and simple.
Old 03-14-2019, 11:51 PM
woodcrest
CF Member
Sounds like a plan!
Curious to hear results....
woodcrest is offline
Old 03-15-2019, 12:19 AM
95LT1ZF
CF Senior Member
95LT1ZF's Avatar
Put me on the list of folks that used Water Wetter. I used it in the IROC and it definitely helped.
95LT1ZF is offline
Old 03-15-2019, 02:11 PM
cuisinartvette
CF Senior Member
St. Jude Donor '05
Sounds like the LT5 or most big blocks...they are one giant heat sink and most yr vettes have lousy airflow underhood. Once they reach a point they want to keep creeping
My old Z felt like it would lose a ton of power once it started creeping past 200, wouldnt even bother getting on it.
cuisinartvette is online now
Old 03-15-2019, 02:17 PM
aklim
CF Senior Member
aklim's Avatar
My plan is this:
I agree that the pressure is to increase the boiling point but do you think that the water at a given temperature and pressure has less energy than if you had it at a higher pressure? Or does it not matter since it is conductivity that we are talking about? It's been a while so I might be rusty on that.
aklim is offline
Old 03-15-2019, 02:45 PM
CF Senior Member
Any heat transfer I've done uses pressure only to determine the drop in flow across a heat exchanger. So I mean if it were to slow down that will effect delta T but if it has any meaningful impact? Not that I've ever seen. However with gases that's different because you now have a compressible fluid and densities change and all that.
Old 03-15-2019, 11:04 PM
aklim
CF Senior Member
aklim's Avatar
Fair enough. When is the test?
aklim is offline
Old 03-16-2019, 12:33 AM
CF Senior Member
When I have some time. Maybe a week or two.
Old 03-16-2019, 12:02 PM
  #33
KyleF
CF Senior Member
Originally Posted by Tom400CFI View Post
As I said above...use a soap with little or no foaming agent. They put foaming agent in soap so it makes...foam. And that makes people "think" that it's working. The foam treats peoples' psychology. The soap is what thins water and helps it clean better.
It wasn't a response directed to you... and the person it was specified Dish Soap
Lighten up and take a joke
KyleF is offline
Old 03-16-2019, 12:07 PM
  #34
KyleF
CF Senior Member
You should test with and without pressure and verify there is not change.
You are correct in you analysis about how it interfaces with it's surroundings. Don't forget that interface can be effected by pressure. Also, materials act differently when shifted in their phase diagrams. I am not sure on water, would have to do some research if preventing water from boiling at 212 would change any of it's behaviors at 260 if still in liquid form.
KyleF is offline
Old 03-16-2019, 12:19 PM
  #35
wadenelson
CF Senior Member
wadenelson's Avatar
Originally Posted by cuisinartvette View Post
If it did why isn't it already in coolant?
"Water Wetter" belongs right alongside STP (benefit unknown), Slick50 (benefit unproven), SeaFoam(benefit unknown) and various additives claiming to "undo" the harmful effects of alcohol in gasoline. (These same additives once WERE methyl alcohol, to "getter" any water in your tank, like HEET)
Get your cooling system working properly and skip all the snake oil.
Start with a new radiator cap and a 30 minute pressure test. 50/50 coolant/distilled water.
wadenelson is offline
Old 03-16-2019, 01:50 PM
  #36
aklim
CF Senior Member
aklim's Avatar
Originally Posted by wadenelson View Post
Right alongside STP (benefit unknown), Slick50 (benefit unproven), SeaFoam(benefit unknown) comes "Water Wetter"
Get your cooling system working properly and skip the snake oil.
The snake oils have been proven to benefit the manufacturer. Since it is priced low enough, people don't feel the pinch and don't expect much more than what the imagination provides.
aklim is offline
Old Yesterday, 10:06 AM
  #37
84 4+3
CF Senior Member
I mean maybe, but it still is incompressable so who knows. I'd have to rethink the test setup if I were to pressurize it. I have no real way of doing that on a test bench with the pumps I have. They won't flow well with any significant head.
Old Yesterday, 05:16 PM
  #38
RWDsmoke
CF Senior Member
I used water wetter in a v8 s-10 years ago. I was using two small electric fans because I didn't have room between the radiator and water pump for a proper sized fan. It dropped the temperature 15 - 20 degrees driving in city traffic. As others have said, no need for anything extra if everything else is working like it should.
RWDsmoke is offline
Old Today, 09:24 AM
  #39
KyleF
CF Senior Member
A fluid's volume doesn't change under pressure (appreciably on a macro scale) is true, but it doesn't mean it doesn't experience pressure. This is why it does not boil in a cooling system.
One thing I know is, if you take a fluid, put it under pressure and heat it passed it's non-pressurized boiling point , then release this pressure it will consume more heat (energy) to phase change to a gas. This is Latent Heat of Vaporization. Now, we are not doing this in our cooling system, but it is just an example of how playing with pressure/phase can effect behavior.
Really to do an apples to apples test, It would need to be under pressure in my opinion. IT would just be another variable that would remain having an unknown effect.
I am not sure of your test bench set up, but a cars cooling system is closed. Under pressure both sides of the pump should see pressure. The resistance out and the pressure pushing in should be relatively close in a closed system. The head resistance should still only be the flow losses. Again, I would have to have a look at what your set up is to fully understand.
KyleF is offline
Old Today, 09:41 AM
  #40
Tom400CFI
CF Senior Member
Tom400CFI's Avatar
I can't see why it needs to be under pressure. If the stuff works, it works and it should clearly demonstrate better heat transfer under pressure or not.
Tom400CFI is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
